RV.Net Open Roads Forum: Tech Issues: Connect small wires to auto battery post?
 > Connect small wires to auto battery post?
Ramblin' Ralph
Central California Coast
Posted: 01/13/21 06:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'm replacing my RV/marine battery, that has a wingnut terminal for small wires, with one that doesn't. So I'm looking for something that will connect to a large battery post (along with the battery cable) and give me a way to connect small wires under a wing nut. I don't want to replace the end of my battery cables to do this.
Thanks,
Ralph
Ralph
2006 GMC 2500HD, XCab, SB, 6.0L w/2001 Lance 845
Bilstein Shocks, TorkLift Stable Loads, 125 watt solar
My RV Travels Webpage / Yearly Campsite Map / 715 Campsites / YouTube Videos /
Instagram / Twitter
Dutch_12078
Winters south, summers north
Posted: 01/13/21 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
These adapters will get the job done:
Schumacher BAF-MT2 Coated Marine Terminal End
Dutch
2001 GBM Landau 34' Class A
agesilaus
North Florida
Posted: 01/13/21 07:22pm Link  |  Quote  |  Print  |  Notify Moderator
That is for battery cable sized wires, not small wires.
So far as I know you can either get crimp on ring terminals or more commonly just loosen the battery cable and stick the bare end of the wire down between the cable clamp and the terminal and tighten the clamp down. The half a@@ method.
There is this: Keadic Battery Terminal
Tho I've never seen one.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
enblethen
Moses Lake, WA
Posted: 01/13/21 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
Look in the under hood fuse/relay box for hot all the time spare terminal or fuse position.
Could connect to either terminal post one or two in fuse/relay box.
What amount of power do you need?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
D.E.Bishop
Eagle Rock, CA
Posted: 01/13/21 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Look up Cardid 2009 GMC Canyon battery terminals. That should work.
"I travel not to go anywhere, but to go. I travel for travel's sake. The great affair is to go". R. L. Stevenson
David Bishop
2002 Winnebago Adventurer 32V
Back to a 2006 Suzi GV
Roadmaster 5000
Roadmaster Invisibrake
bob213
Fresno, CA
This should work:post connector
If your battery has screw in side posts they make one for that as well.
Like these: side post adapters
* This post was edited 01/13/21 07:57pm by bob213 *
time2roll
Posted: 01/13/21 08:23pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.ebay.com/c/1900471593
https://www.summitracing.com/parts/aaf-a........mea7QBhBSnQ-DmNJQoZRGXq_dVYaAkWYEALw_wcB
https://www.ebay.com/itm/HD-2x-Car-Batte........w-Positive-Negative-Clamps-/113688325276
675w Solar pictures back up
ItsyRV
Desert SW
Posted: 01/13/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a picture to show you, but before I added the auxiliary power connection panel to the coach battery, I went to the local auto store and they had these spade "Y" wire connector for top post batteries that the V part went under the thick battery cable and the other end had a screw terminal for lugs or wires. It's similar to what you are being shown above, but instead of a large battery cable clamp, it was a semi thick spade connector type with a second smaller post for attaching wires, spaded or ring connectors that didn't interfere with or required altering the original battery connector.
They also had a set that had two and three aux connections but at that stage, using a dedicated auxiliary power connection bar would have been better. If you have a side post, they had a similar set just for side post that had ring connectors instead of spade connectors.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
agesilaus
North Florida
Posted: 01/13/21 09:11pm Link  |  Quote  |  Print  |  Notify Moderator
I could make one of those easy enough, a longer bolt, a brass spacer from Ace Hardware, and a nut. Interesting kludge.
gbopp
The Keystone State
Posted: 01/14/21 04:00am Link  |  Quote  |  Print  |  Notify Moderator
These should work, the OP does not want to replace the battery cable ends.
