RV.Net Open Roads Forum: Toy Haulers: 13'5" clearance
Search only in Toy Haulers
 > 13'5" clearance
RCMAN46
NorthWest
Posted: 01/15/21 07:21am Link  |  Quote  |  Print  |  Notify Moderator
A suggestion on how to determine the actual height of your 5th wheel.
When you have the 5th wheel loaded as you will most likely use it go back to the dealer where you purchased the unit. Make sure tire pressures are at you towing pressures.
Pull into one of their stalls and stop with highest point under the doorway. Crawl up on top and measure the distance from the highest point of the 5th wheel to the door opening. Then measure from door opening to the ground. Do the math and you will know the exact height of the 5th wheel.
I did this before I took delivery of my 5th wheel to make sure it would go into my shop building. My dealer was more than willing to do this for me.
joelc
Cedar Point, NC
Posted: 01/15/21 08:53am Link  |  Quote  |  Print  |  Notify Moderator
You should not have problems as long as you don't go under a bridge lower. My 5er is 13'6"
BurbMan
Noblesville, IN
Posted: 01/15/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Madhatter1 wrote:
At least it's only a $1500 mistake.
Yes, $1500 for the a/c unit, not including the damage to the trailer as the a/c is ripped out of the roof and pushed backwards into the ceiling....
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
valhalla360
No paticular place.
Posted: 01/15/21 12:30pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, as if it's going to neatly pop off with no other damage. I'd be shocked if you come in under $10k in damage if the air/con hits.
Yes, it is standard industry practice to update the signs based on field measurements and yes, there is a fudge factor.
Even if they omit the update, you won't find one that is significantly off for long. The first truck to get wedged under, someone will be out quickly to verify. While unlikely to cause serious damage with an RV, you can expect a bill for any damage and for an inspection to verify the bridge is unharmed. Typically, your insurance will cover it but if they decide you were grossly negligent by purposely going under a bridge posted lower than your height, they may at a minimum give you a hassle before paying.
Of course that fudge factor accounts for the fact that vehicles are built on suspensions that include springs. So a static measurement in your driveway can easily be off by 3-4 inches if you hit a bump and the trailer jumps up at the wrong time. That static measurement is really only good if you creep under the bridge at less than idle speed.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Sjm9911
New Jersey
Posted: 01/15/21 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have never once sceen the RR guys go after the truck owners for damage to the bridge. And only once have sceen them inspect it. They dont bother with that stuff up here. It may be diffrent in other places.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Madhatter1
Madeira Beach FL
Posted: 01/15/21 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
I would creep slowly under a questionable overpass and If I touched it would only be the AC. Not going to fly under at 40 or 50MPH and hope for the best. Although it is funny to imagine. When I pick up the camper I will measure while on the truck. Will also hit the truck scales to get total weight.
Original question is what JoelC answered. But I will be careful and plan my routes. There is right now just one questionable bridge in Unionpoint GA that I can detour around. Other than that we are open highway. But do plan to go to some areas I will research first.
Thanks for the responses.
valhalla360
No paticular place.
Posted: 01/17/21 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I've seen it several times working for a state DOT.
The worst one included closure of the bridge and emergency work to replace it. The insurance company was hit up for several million and they didn't even bother to fight it.
The funniest was when a pickup pulling a boat decided to go around the bridge closed signs and he was found the next morning, with the truck hanging by the trailer from the bridge beams. They had only placed the flase decking so it fell between the beams and the trailer hung up. That one was only about $75k for inspection and repair of the damage.
deltabravo
Spokane, WA
Posted: 01/18/21 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Madhatter1 wrote:
since top height is the AC unit and cannot damage bridge structure if it touches.
A roof top A/C unit isn't going to damage a bridge. Instead, the bridge will do a very fast "air conditioner delete" mod for you, then you won't have to worry about height anymore.
 > 13'5" clearance
