RV.Net Open Roads Forum: Dinghy Towing: 4 down towing vehicles
Search only in Dinghy Towing
Open Roads Forum  >  Dinghy Towing  >  Vehicles
 > 4 down towing vehicles
Poppy2003
Lake Anna, winter storage.
Posted: 01/15/21 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
I'm planning to buy used Ford F150 4x4 cab, automatic or standard to tow on all 4s, is this a right toad?, or what is the best dingy??, not planning to spending money (retired) for modifications.
Monterey, California
Posted: 01/15/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Ford is the best source for this information.
Bumpyroad
Virginia
Posted: 01/15/21 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
look up owner's manual for that make model year etc. and see what they say.
bumpy
camp-n-family
London, Ontario
Posted: 01/15/21 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Is it the right toad? Depends on what you’re towing it with. A full size truck is a pretty heavy vehicle to tow around. It will exceed the ratings of a lot of MHs. It may be ok behind a class A but probably not behind most class Cs.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
Posted: 01/15/21 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Keep planning but check closely before you buy...4 down towable, MH max tow weight etc.
SDcampowneroperator
South Dakota
Posted: 01/15/21 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
We saw many a pick up towed 4 down behind MHs, As ( rear and front gas or diesels) and Cs ( again either fuel) both auto trans and manual. 4 WD trucks have a neutral in the selector switch to allow towing.
It. also allows carrying other cargo like a M/C. Your expectation of power,economy and gcvr is the limiting factor. Definitely install auxiliary brakes on the tow. You cannot have a heavy vehicle pushing the coach.
A consideration if you are adventurous in your travels that puts you in a situation is,
I have seen and done backing up a 4 down many times, just have a spotter watch the front wheels. Its no different than backing a trailer except for the front wheels, if you have to turn sharp they may not follow the turn. It is a myth that 4 down cannot be backed or that damage will happen. Hitches that can pull can also be pushed on.
Its MFGR Cover Butt Speak.
Janss
Sedona, AZ
Posted: 01/15/21 09:09pm Link  |  Quote  |  Print  |  Notify Moderator
Look at the Dinghy Guides:
Dinghy Guides
Even if your chosen vehicle is on this list or any other towable list....Before actually buying a vehicle, be sure to look at it's owner's manual under "recreational towing" or similar (not to be confused with roadside assistance towing).
2002 Itasca Suncruiser 32V
2012 Suzuki Grand Vitara
dodge guy
Bartlett IL
Posted: 01/15/21 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
If it has a N position on the 4WD selector then chances are good it's 4 down towable. But always check the owners manual to verify.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
sch911
Rochester Hills, MI
Posted: 01/16/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Most likely too heavy for a Class C, or a gas Class A. What MH do you have?
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
ranholago
CA
Posted: 01/16/21 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
IF you decide on a f 150 be sure it is a "manual" activated transfer case, IF it is an electronic activated transfer case ( where you push a button vs shift a shifter to engage 4x4) be sure that the dealer is able to install the program/access to the computer of the vehicle to enable "N" on the transfer case. Went through that and was unable to get a dealer able to enable the computer to put the transfer case in neutral.
Just something to investigate and to check before you pull the plug on a f 150
