RV.Net Open Roads Forum: Fifth-Wheels: Newer 5ers, Slider Hitch Required For Short Beds?
 > Newer 5ers, Slider Hitch Required For Short Beds?
Ron3rd
Upland, CA USA
Posted: 01/18/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
Gonna go with the Superglide auto slider
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
cummins2014
Utah
Posted: 01/18/21 09:34am Link  |  Quote  |  Print  |  Notify Moderator
I hope you did your homework on the Superglide, and the limitations on hitching ,unhitching . Had a friend grow tired of it after couple years ,and got rid of it ,that and the weight to deal with. Hopefully you are aware of all this, they are not cheap .
MFL
Midwest
Posted: 01/18/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Yes, more to consider than just that it auto slides. Is there a chance, with your model truck, that it could cause the pin box to hit the tailgate, when sliding. I do consider this to be a quality hitch, that works well for many.
Jerry
cummins2014
Utah
Posted: 01/18/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Yes, very good chance it could hit, it was a concern. I had the same concern when I pulled my Reese slider back when backing into my driveway, but it cleared . If I remember the Superglide went further back then my Reese manual slider . I had the luxury of checking it out gradual ,not sure you have that with the Superglide , once it starts back I think it goes to until it stops at the end of its travel . A little late in the game at that point .
Early on I considered a Superglide, but definitely not after the trouble I saw with my friends Superglide . Reason I considered it was just not having to deal with that manual slider . I think that is one of the biggest reasons why so many cabs ,and back windows get damage is thinking they can get away from having to use a manual slider , I know I hated dealing with it.
I think Pullrite makes quality products, but IMO the Superglide just has too much baggage with it. .
I solved the clearance problems with a short bed truck ,having the rounded corners on a fifth wheel front cap ,its a game changer . ,and definitely the Andersen hitch .
cummins2014
Utah
Posted: 01/18/21 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Just double checked the travel distance on the Superglide, its 14" ,compared to 10 " on my Reese. Its definitely something to consider, just depends on where that Superglide is mounted ,and definitely the pin box style . If I remember now, with my Ram I thought the Superglide would hit the tailgate with my Montana fifth wheel ,and Morryde pin box . Positive it would hit my tailgate with this newer fifth wheel ,and the Lippert pin box .
4x4ord
Alberta
Posted: 01/18/21 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have no need or desire for a sliding hitch but if I was to get one it would be an auto slide. If I had to manually slide my hitch I would never slide it. My father has taken out the back window of his Dodge twice in the 16 years that he has owned his truck and he has a manual slider ... that he doesn't use.
2017 F350 SRW Platinum short box 4x4.
B&W Companion
Njmurvin
Simi Valley
Posted: 01/18/21 01:38pm Link  |  Quote  |  Print  |  Notify Moderator
In 16 years and 2 different 5th wheel trailers (with my 6.5' Ram bed), I never once had an issue hooking/unhooking in developed campsites. I realize it had the potential for issues, but it was never an issue for me.
That said, I love the Andersen on my new truck. Super light and super quiet.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
ford truck guy
Pennsylvania
Posted: 01/18/21 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
I towed my 3 different fivers with a Superglide and never a problem..
IF I ever have to go back to a short bed ( I WONT ) it will be an auto slider Superglide.. Great company to work with... Great people to talk to... Great Hitch !
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Curly2001
Tucson, Arizona
Posted: 01/19/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
Just one more note, make sure of your bed/hitch height before you go with a slider. My trailer really doesn't need the slider but I thought I had to have one. The slider will add to your hitch height and it could make your trailer nose high. I had that issue with mine. Got rid of the slider and so far we are good.
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
MFL
Midwest
Posted: 01/19/21 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Curly
Ha, famous last words. Just kidding, glad a non-slider works for you! Having a GM is a big help, due to the longer than other brands distance, from axle center, to rear of cab.
I've towed with several 6.75 bed Fords, and a couple different FWs, while never having a slider hitch. No problem so far, and been working fine since 99.
Jerry
