RV.Net Open Roads Forum: Fifth-Wheels: Newer 5ers, Slider Hitch Required For Short Beds?
 > Newer 5ers, Slider Hitch Required For Short Beds?
Ranger431
Huntsville, AL
Posted: 01/21/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
I’ve got a short bed F350 and a 2020 Jayco Eagle I have a manual slider, and am very glad I do. I don’t need to use it all the time, but there are a few tight spots I’ve been in that I was very glad I had it. The manual is a little bit of a pain, but much less of an inconvenience than replacing a back window.
2020 Jayco Eagle 355 MBQS
2011 Ford F-350
Ron3rd
Upland, CA USA
Posted: 01/22/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
cummins2014 wrote:
Ron3rd wrote:
Gonna go with the Superglide auto slider
I hope you did your homework on the Superglide, and the limitations on hitching ,unhitching . Had a friend grow tired of it after couple years ,and got rid of it ,that and the weight to deal with. Hopefully you are aware of all this, they are not cheap .
I've used the hitch before with no problems. Two friends have the hitch with no problems. I'm familiar with the Superglide
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
schlep1967
Harrisburg, PA
Posted: 01/22/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
You won't regret it.
I saw a New Dodge with a new 5th wheel. The new Dodge had a nice new dent in the back corner of the cab.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
Ron3rd
Upland, CA USA
Posted: 01/22/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
I do have interest in the Anderson too
Bayley
Meridian
Posted: 01/25/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Ram short bed and an Andersen ultimate hitch over a B&W turn over ball and your worries are over. I have jacked pretty hard at times and never come close to the cab.
Semper Fi
Tony, Darlene & the boss Bentley!
2013 Ram CTD, Ride-Rite Air Bags, B&W Turnover Ball and Andersen "Ultimate 5th Wheel Connection".
2014 Arctic Fox 29-5K 5th wheel with Reese Airborne Pin Box.
Ron3rd
Upland, CA USA
Posted: 01/26/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
Just ordered the Andersen. Went with the standard rail kit though.
cummins2014
Utah
Posted: 01/26/21 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Great choice .
Hammerboy
Zeeland, MI
Posted: 01/27/21 06:22am Link  |  Quote  |  Print  |  Notify Moderator
I had the Superglide on a previous truck and fifth about 15 years or so ago and had it for about 4-5 years before I parted ways with it. Quality built hitch but I grew tired of the limitations of hitching and unhitching as well. I think it was like 7 degrees or so in either direction or you would have to disconnect the head from the rest of the hitch and the same for hooking back up if you cannot get a relatively straight shot. Not to mention I was always cleaning and lubing the slide tubes.
My current rig I have a 18K BW Patriot non slider with my shortbed which I like much much better. This past spring I idled my slider base and purchased a fixed base off Marketplace as I never used the slider function in any sort of turn. The only downside of course is the potential to kiss the cab but in the 5 years with our current rig I cant say I've ever been close, just have to be aware. The 18K Patriot I have now is also much lighter which means I can easily remove it by myself in (head pops off by simply grabbing the handles) without help or the aid of a winch. When I had my slider I used a cheap Harbor Freight electric winch to lift it out.
Cannot say enough good about B&W, well designed and build quality, built here in America and a great company that stands behind their products.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
