RV.Net Open Roads Forum: Honda 2000i tips and tricks for changing oil.
 > Honda 2000i tips and tricks for changing oil.
path1
Varies with weather
Posted: 01/15/21 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
As the title says...any tips or tricks for not spilling any oil. I haven't mastered it yet, even though I got a little funnel that screws in I always seem to make a mess.
cgjt
western new york
Posted: 01/15/21 04:45pm Link  |  Quote  |  Print  |  Notify Moderator
Although I have a 2000w Champion generator, I bought off of eBay a screw in adapter that fits into the oil fill hole and allows a quick no mess drainage of the unit. I am almost positive that they had these listed for other makes including the Honda. If I can find the listing I will forward it. Good luck and stay safe.
Near DVNP, California
Posted: 01/15/21 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
Consider a cut to fit small plastic funnel.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
RoyF
Fayetteville Arkansas
Posted: 01/15/21 07:19pm Link  |  Quote  |  Print  |  Notify Moderator
For adding the oil, I use a plastic syringe. You can find them at Amazon.
I forget the exact size. I think mine is around 50 ml, which is about 1.5 ounces. With a syringe, you can put the oil in without spilling.
FLY 4 FUN
Alberta
Posted: 01/15/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
I elevate mine on a small stool and insert the aftermarket aluminum funnel (threaded) and then tip it on its side so oil can run out into a drain pan. Once done, add the 400ml oil as recommended and clean up any drips. Should be good to go. Doing it on a scrap of cardboard is also a good precaution.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
Bobbo
Wherever I park
Posted: 01/15/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.amazon.com/EU3000I-EU2000I-EU3000IS-Generator-SHIPPING/dp/B01I24M5YE
Bobbo and Lin
IDman
Oklahoma
Posted: 01/16/21 11:04am Link  |  Quote  |  Print  |  Notify Moderator
Should have bought a Yamaha.
theoldwizard1
SE MI
Posted: 01/16/21 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
more expensive, but more useful for other things Form-a-funnel
Bobbo
Wherever I park
Posted: 01/16/21 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
Years ago I bought a 3 pack of flexible cutting boards. I am still using them to make ad-hoc funnels or protective shields. Dirt cheap. They cut quite easily with ordinary scissors.
JimK-NY
NY
Posted: 01/17/21 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
So it appears the best technique would be to use a screw in plastic tube when emptying and to slowly fill with a syringe. Or you could just grab a couple of paper towels.
