RV.Net Open Roads Forum: Newbie trailer owner, question on water pressure pump
 > Newbie trailer owner, question on water pressure pump
RetroAirBnB
California
Posted: 01/15/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
I bought a trailer for my side yard to create an AirBnB.
Everything is powered up and running. There's a panel on the wall where I can check battery charge level, and levels in the tank. At the bottom of that panel, there are two red lighted switches. One turns on the hot water heater (which sparks and fires up). The other turns on the pump for water pressure.
I ASSUME that the water pressure pump should ONLY be turned on when my renters actually need water pressure. Otherwise, if the pump is left on, it will burn out? Am I right in that?
* This post was edited 01/16/21 09:07pm by an administrator/moderator *
dodge guy
Bartlett IL
Posted: 01/15/21 09:49pm Link  |  Quote  |  Print  |  Notify Moderator
The pump will run till it builds pressure, then it turns off till the pressure drops, such as opening a faucet. I would leave it off till someone is using it.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
camp-n-family
London, Ontario
Posted: 01/15/21 09:53pm Link  |  Quote  |  Print  |  Notify Moderator
You only need it if pumping water from the on-board fresh water tank. If you have the city water connected by hose you don’t use the pump.
If you are pumping from the tank you can turn it on and leave it on (when trailer is in use). It has a pressure sensor and will cycle as needed on its own.
Just in case you’re not familiar with the sewage side of things......if you have full sewage hookups do not leave the valves open. Keep them closed until tanks are close to full, then drain. Two reasons; you won’t get sewer gas coming back into the trailer, and the tanks need liquid in them to keep the solids soft and moving. No fluid in the tanks and you will get a Pooh and paper pyramid that is hard to flush out.
Where yo need to be careful is that your tenants know when and how to empty the tanks. If they overflow you will have a serious and smelly mess inside.
* This post was edited 01/15/21 10:01pm by camp-n-family *
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
afidel
Cleveland
Posted: 01/15/21 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
I'll just add that that's generally true but I've been in a situation a few times where I had a city water connection but I still used my pump. If you're at a park where the water pressure is terrible you can use your fresh water pump and the city water to get nearly unlimited water at full pressure (my 20 gallon tank lasted a full week and wasn't near empty but I had full pressure showers the whole time =)
I doubt this is relevant to the OPs situation, just putting it out there for general information =)
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
QCMan
Independent Republic of Horry
Posted: 01/16/21 06:45am Link  |  Quote  |  Print  |  Notify Moderator
Pity the poor renters that think it is just like a house!
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
kellem
Shenandoah valley,VA
Posted: 01/16/21 07:00am Link  |  Quote  |  Print  |  Notify Moderator
As long as you have water in fresh water tank, the pump can be left on as it only cycles on demand.
I personally as part of standard operating procedure, would turn off pump when trailer is not being occupied.
Bishop area, California
Posted: 01/16/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I don’t leave my pump on, kellem.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
bigorange
Tucson, AZ
Posted: 01/16/21 08:50pm Link  |  Quote  |  Print  |  Notify Moderator
If it’s in your side yard, why not just run a hose to it and not worry about fresh tank and water pump?
Not all those who wander are lost. - Tolkien
2018 Cherokee 235B 5W
2011 Ram 2500 CC SWB SLT 4WD 6.7 CTD 3.73
B&W Turnover Ball + Companion Slider hitch
2003 Sierra T22 TT - Sold
blaczero
Posted: 01/23/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
I think the OP didn't realize he won't need the pump if he's got his hose going to city water connection.
ken56
Tennessee
Posted: 01/23/21 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Wait until you go to empty the tanks the first time. You will most likely have a plug from over use of TP and too little water when flushing. Good luck.
