Texsinbad
While we are out and active during the day, when it gets dark, we enjoy watching movies/shows. That said, we are planning on replacing the tv in our new Rockwood 2205S trailer, which we will pickup in a few weeks.
We know that you have to replace the wall mount and make the support wall bigger/stronger, but we would like to hear from anyone who has actually done it.
We will also be adding a sound bar too.
Any tips or suggestions would be appreciated.
Thanks
Old-Biscuit
Verde Valley
WHat size is OEM TV?
What size are you wanting to replace it with?
Many TVs use same mounting
And many of the new TVs are very light weight.
We had a 25" analog HEAVY TV in a cabinet. Took it out...made a cabinet door (huge storage area)
I installed a 32" Vizio on the face of cabinet door
That was in 2008 and still works fine.....no mounting issues etc
Check out the weight on the TV you want to use....not real heavy so doubt if you would have to do anything but swap TVs
Sound bars are not heavy items either....if mounting holes don't line uup with any wall 'studs' just use 'toggle bolts'
US NAVY------USS Decatur DDG31
Durb
NW
We did. Took all the measurements then picked a TV up from Costco with the single criteria of physically fitting the space. I also bought a swivel extension bracket from Costco and made it work. These are extremely adjustable. We use a lightweight bungee to hold the TV in place when traveling. Went from 25" to 38", so much better.
Our sound bar sits on a shelf below the TV so that was easy. No sub woofer but we haven't missed one.
MitchF150
Puyallup, WA
Nice floor plan on the Rockwood. I too have a Rockwood "Mini Lite" but the 2511S. Looks like it already comes with a 32" TV. Same as mine. Looks like yours mounts on the wall, while mine is in a cabinet and swings out with a ton of storage behind it (that's where I have the Blu-Ray player and more storage)
Since yours does hang on the wall, you could get a bigger one, but you might have to lower the bracket... But really, you aren't going to get much more in that space for the effort involved in doing it.
But like Biscuit said, all the new flat screens are pretty light and the same bracket can be used unless you plan on going for some 55" thing.. ![smile [emoticon]](http://www.rv.net/sharedcontent/cfb/images/smile.gif)
Are you going to pop for the Theater Seats too? We swapped ours out for them and the heated butt and back massage is awesome!
![[image]](https://i.imgur.com/7CoV6Obl.jpg)
Good luck! Mitch
Lake Crowley area, California
It’s easy! Measure carefully and get the biggest one that will fit. If you dry camp, compare watts however.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
rlw999
Washington State
When we put in a TV that was 10" larger than the original, the new, bigger TV weighed less than the original, so we didn't replace the bracket, but did have to drill holes lower on the bracket to get it to fit in the same space.
Acampingwewillgo
With a vintage 96 motorhome, the old tube 19" just didn't quite make it. While I played with different locations with flat screens, I finally ended up hanging a 50" from the ceiling which is hinged. I've had this now for several years and it works well.
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
campigloo
Baton Rouge, La
Lwiddis wrote: It’s easy! Measure carefully and get the biggest one that will fit. If you dry camp, compare watts however. .
We boondocks a !ot. We put a 12v in. Works great with a fraction of the draw.
Ron3rd
Upland, CA USA
Old-Biscuit wrote: WHat size is OEM TV?
X2 You might be able to go to the same mount
2016 6.7 CTD 2500 BIG HORN MEGA CAB
2013 Forest River 3001W Windjammer
Equilizer Hitch
Honda EU2000
MikeDupont
TX
We got the largest TV that would fit into the space that we wanted it to go into. We got a completely new (stronger/heavier) mount and mounted it thru the wall (interior) against a support piece of 1/2" plywood. I didnt trust the 'studs' to carry the load.
