RV.Net Open Roads Forum: Fifth-Wheels: Removable 5th wheel hitch?
 > Removable 5th wheel hitch?
Page of 5
Sande
Washington
Posted: 01/16/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
We have a 3500 RAM drw shortbed which we currently use with our artic fox 811 camper.
We are thinking about getting a 5th wheel and also keeping the camper for some trips.
Is there a sliding 5th wheel hitch that can easily be taken off the truck in order to slide in the camper?
agesilaus
North Florida
Posted: 01/16/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
If your truck has the bed prep for a fiver hitch then you can easily find a hitch that can be installed or removed in ten mutes and leaves a flat bed in the back of the truck. B&W and Pullrite as well as others make those hitches. Without the bed prep then you can remove the hitch but it will leave rails in the bed.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
rich and char
N.J.
Posted: 01/16/21 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Pull Rite makes the "Super 5th" with a complete empty bed design when uninstalled, no rails left in bed. Less than five minutes to install or uninstall, and brakes down to pieces so its not to heavy. A solid hitch.
2011 F-350/CC/LB/Drw/6.7L
2013 Cedar Creek 36 CKTS "Pearl Edition" Trail-Air Pin Box
Pullrite 20.5K Super 5th
rhagfo
Portland, OR
Posted: 01/16/21 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
What year is the Ram 3500?
Post 2013 you can get the parts to install the factory 5er hitch prep.
cummins2014
Utah
Posted: 01/16/21 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
A sliding hitch , no not a chance unless you have some sort of hoist , or taking it apart . Turnover ball , and the Andersen hitch . Clean bed when removed . Also easily removed by one person .
guidry
Texas Cajun
Posted: 01/17/21 06:28am Link  |  Quote  |  Print  |  Notify Moderator
My BW came off but left the rails. I just used some 2x4”s then a 4’ plywood and put my camper on top. Never had any problems.
phillyg
SWFL
Posted: 01/17/21 07:53am Link  |  Quote  |  Print  |  Notify Moderator
I'm not aware of any lightweight sliding hitch.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
JRscooby
Indepmo
Posted: 01/17/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Could the pin be left latched in the hitch, and the landing legs used as a jack to lift hitch out?
Sande
Washington
Posted: 01/17/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
Wow, lots to think about! We are both almost 70 and not as strong as we used to be.
Maybe a trailer would be better.
Next question - has anyone carried fishing kayaks (12ft long, 140 lbs each) on the back of an RV?
miltvill
Ft. Lauderdale FL
Posted: 01/17/21 09:09am Link  |  Quote  |  Print  |  Notify Moderator
12 feet long and 140 pounds each. Sounds like a Hobie Pro Angler kayak for each kayak to weigh that much. A 5th wheel with a garage would work best.
Or a get a TC and tow the kayaks behind it on a trailer.
2020 GMC Denali\Duramax 3500HD Dually Crew Cab
Sold-Trail Cruiser TC23QB
Page of 5
