RV.Net Open Roads Forum: Fifth-Wheels: Removable 5th wheel hitch?
 > Removable 5th wheel hitch?
Page of 5
Walaby
Georgia
Posted: 01/24/21 08:17am Link  |  Quote  |  Print  |  Notify Moderator
I have the Pullrite Superglide. If I need to remove it, I lift it up locked to kingpin, and then set it down on a table with wheels. The table I use can raise or lower, so I can level the trailer, and then raise the table to take the weight off the pin if I want. I can cover it up and leave it outside, or wheel it into my garage.
Takes about 10 mins and no exertion.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Sande
Washington
Posted: 01/26/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
Thanks Mike, so them nothing is left in the truck bed? We need it empty for camper use.
Thanks!
Cummins12V98
on the road
Posted: 01/26/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
Get a solid sliding hitch, auto or manual. Forget the lightweight folding-bed deflection model and do as suggested and use pin box to lift the hitch right out of the bed of the truck.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
TxGearhead
Posted: 01/26/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I never understood if the OP had the towing prep package...pucks and a ball. I've got a PullRite 2600 single point pulling a 18,000# 5th. No issues. I would recommend it but I think the Andersen may have a model with a rearward offset that could work better with a shortbed.
Not sure if a Reese Goosebox would work on a short bed.
I'm thinking about going to the GEN-Y pinbox myself.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
ReneeG
Meridian, Idaho
Posted: 01/26/21 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
Hensley's TrailerSaver BD3 removes easily and you can purchase a sliding base for it. We had the sliding base, but never used it.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Cummins12V98
on the road
Posted: 01/26/21 04:01pm Link  |  Quote  |  Print  |  Notify Moderator
What does the whole assembly weigh?
fowlthing
Roger, AR
Posted: 01/26/21 06:51pm Link  |  Quote  |  Print  |  Notify Moderator
Anderson hitch weighs 35 pounds and works great super easy to remove.
love mine... my brother has towed a fifth wheel to Alaska and back with the Anderson hitch
2017 Ford 350 SRW
Grand Design Solitude 375RES
may switch to a Ram
cummins2014
Utah
Posted: 01/26/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
No matter how civil the thread remains, we get this [emoticon]
cummins2014
Utah
Posted: 01/26/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Same here have got many miles towing with the Andersen. I recommended one to a friend he has the aluminum version . No bed defection , no folding . He too has towed to Alaska , and back . Said the roads were a bit rough , but no issues . That’s a pretty good test for truck , trailer, and most importantly the hitch .
Cummins12V98
on the road
Posted: 01/27/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
To tell you something the guy I have mentioned before that towed his 18k Mobile Suites with the Andersen aluminum in his RAM DRW admitted he had bed deflection. I happened to see him a week ago and noticed he now has the GEN-Y GooseNeck pin box. He says he loves it!
FYI he is an ANDERSEN Dealer.
He also mentioned he loves not having to remove a hitch, even at 35#.
Page of 5
