RV.Net Open Roads Forum: General RVing Issues: Dometic refrigerator frost and ice
 > Dometic refrigerator frost and ice
Old-Biscuit
Verde Valley
Posted: 01/17/21 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Do the dollar bill test (bill between seals/frame door closed and pull it out---should be tight/have resistance
Do it in Several places
Clean seals/frame so you get good clean contact between the two
IF seals are not making good contact you can 'reset' them:
Place cottonball under seal in each corner
Then WARM entire seal using hair-driers (do not overheat but need to get the whole seal warm)
Then close door and let the warm seals cool///resetting them
If seals are good...dollar bill test then it could just be the warm humid air replacing the cool air when you open fridge doors---especially if you lookie-lou
Model of fridge??????????????
US NAVY------USS Decatur DDG31
Wherever I happen to park
Posted: 01/18/21 04:29am Link  |  Quote  |  Print  |  Notify Moderator
rollindowntheroad wrote:
LOL.... I'm not a youngster, 63 years old here. However, this is my first RV. Thanks for the info.
Ah but to me 63 IS a youngster.. I remember Fridges you had to defrost.
And RV fridges... You still do.
On one thing that will cut down on the frost in the freezer.
KILL or Rip out the ice maker and use a countertop (Portable).. I did.
More ice (up to 26 pounds a day) and less moisture in the freezer due to that "Warm (more than 32 degrees) water thing I mentioned.
And when the counter top unit went compressor up.. All I needed to fix it was a browser.. a phone, a car, a plastic retangle (Credit/debit card) and a knife (to cut the tape on the box).
You need all those for the Built in ice maker too but TOOLS. lots of TOOLS and you may need to remove the fridge to replace one part.
Home is where I park it.
rollindowntheroad
Sebring, FL
Posted: 01/18/21 04:42am Link  |  Quote  |  Print  |  Notify Moderator
To: wa8xym - I remember my mom defrosting the freezer when I was growing up. She set up a small fan in the door and would scrap the frost and ice out.
No ice maker in the freezer in my RV.
dedmiston
The West
Posted: 01/18/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
"I remember the man from the ice house delivering blocks of ice in his horse drawn wagon."
Good lord. Everyone over 40 remembers defrosting their freezer.
Patronize much?
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Posted: 01/18/21 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Patronize much?
I'm not QUITE that old. but... My mother tells me that her father made one of the first Refrigerators in California.
He was a refrigeration engineer workign on the big Fishing processing boats (They moved the fish processing onto boats back than so the fleets could catch more fish not having to return to port to offload)
He converted an ice box to a Fridge.
Alas I never met him. he died just weeks before I was born.
I do recall Grandma however.
doxiemom11
Victoria TX
Posted: 01/18/21 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Norcold 1200 4 dr and I just shut it off, put the food in the big cooler and it defrost and water runs out the tray to the outside. Only takes a couple of hours. I do have to soak water up off the freezer bottoms though. Good time to clean it. We added one of the small fans on the rt side fin area and it has helped a lot. That was the area where the ice started all the time.
Old-Biscuit
Verde Valley
Posted: 01/19/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
Guess you have an older 1200 model....no 'defrost' cycle?
S/N 83170 and lower doesn't have that
S/N 83171 and higher has a 'frost' management power board.
Shuts down cooling cycle every 40-48 hrs
When Food Compartment fin temp reaches roughly 32*F (41-42*F Air temp) the frost management restarts cooling cycle
Freeze temp plate will reach rough;y 22*F...so food stays frozen/no defrosting in freezer
