RV.Net Open Roads Forum: Class C Motorhomes: Updated and solved...Door lock Trimark 30-1050/030-2650
 > Updated and solved...Door lock Trimark 30-1050/030-2650
DaCarmack
Lake Isabella
Posted: 01/17/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Edit for clarity. 030-1050 is the original door handle/lock. Trimark shows 030-2650 as its replacment. unable to find either for sale on the internet.
Good day every one.
Its be sometime sense I've been on here. (2010 is my last PM I found)
Ive looked High and low for those lock in the Subject matter(30-1050/030-2650). This is for a 2004 Coachmen Concord. I can find 060-1650 all day long same with T507. Google shows everything but want I need.
Will/does a 060-1650 fit a in the spot for 30-1050/030-2650?
Thanks for all you assistance
Doug
* This post was last edited 02/06/21 01:21pm by DaCarmack *   View edit history
2005 Coachmen Concord 275ds
enblethen
Moses Lake, WA
Posted: 01/17/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
Does not appear that they are the same shape of opening.
The 030-1050 is nearly square as 030-2650 is curved on one end.
Trimark 030-2650
Why not replace with the same one?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
DaCarmack
Lake Isabella
Posted: 01/17/21 01:03pm Link  |  Quote  |  Print  |  Notify Moderator
enblethen.
You are correct. the 030-2650 is the new updated part number. Good find on there website, but I sill can not fine it forsale on the net.
I will edit the first post of clarity
bobndot
Posted: 01/17/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
this link is related to your model.
https://www.irv2.com/forums/f120/how-to-remove-door-lock-177812.html
DaCarmack
Lake Isabella
Posted: 01/17/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Bobndot.
Thank you first off...While it does relate, still no part number on what he replaced it with
enblethen
Moses Lake, WA
Posted: 01/17/21 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Should be3 available on Amazon.RVdesigner
DaCarmack
Lake Isabella
Posted: 01/17/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Enblethen.
Thank you for the reply. Unfortunately that website only shows the t507 or the number trimark calls it is a 060-1650. If I knew for sure but that would fit I'd buy it in a heartbeat.
enblethen
Moses Lake, WA
Posted: 01/17/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
Does this help any?
Trimark flyer
Or this
Trimark
DaCarmack
Lake Isabella
Posted: 01/17/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
The second one has more information, but it still doesn't tell me where to buy one or if the other model 060-1650 will fit in place of a 030-2650. The joys of rving right. I do thank you for looking also. second set of eyes always helps
enblethen
Moses Lake, WA
Posted: 01/17/21 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
Trimark 060-1650 at Amazon
Both show on Amazon
030-1650
Which one do you prefer? Can return to Amazon very easily.
