RV.Net Open Roads Forum: Im looking for a wiring guide for my Motorhome.
 > Im looking for a wiring guide for my Motorhome.
kathyday1851
Needles, CA
Posted: 01/17/21 10:53am Link  |  Quote  |  Print  |  Notify Moderator
Im trying to wire a generator to dash switch but I need the wiring guide for an Onan 1986 6500 Emerald Plus. I have 4 wires.
I also am trying to figure out what the second fuel line is for. 1 line goes to fuel tank, but whats the second do and where does it go to?
enblethen
Moses Lake, WA
Posted: 01/17/21 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Page 33 for remote wiring
Should have only one line for a gasoline unit.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Carrolton, Texas
Posted: 01/17/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
When you look at the Link supplied, remember, the Start and Stop is a GROUND (negative) circuit. The B+ (positive) wire is for the ON indicator light in the switch and also goes to any Hour meter.
dougrainer
Carrolton, Texas
Posted: 01/17/21 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Correct. Where does that 2nd line attach too on the Genset? Can you post a Pic of that 2nd line? The Onan GASOLINE Fuel pump is a very small PSI pump and will shut down or idle when excess fuel is not needed. There should be NO 2nd line or return line. Doug
Dusty R
Charlotte Michigan 48813
Posted: 01/17/21 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
To the carburetor?
Dutch_12078
Winters south, summers north
Posted: 01/17/21 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
What is the attached end of the fuel line connected to?
Dutch
2001 GBM Landau 34' Class A
kathyday1851
Needles, CA
Posted: 01/17/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
The1 line is hooked up to the generator carb but I have another line that I don't know where it goes
kathyday1851
Needles, CA
Posted: 01/17/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
It comes off the generator at the carb
kathyday1851
Needles, CA
Posted: 01/17/21 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
I'll post a pic in the morning to show you what I mean
enblethen
Moses Lake, WA
Posted: 01/17/21 05:47pm Link  |  Quote  |  Print  |  Notify Moderator
Are you sure it is gasoline powered and not propane fueled?
