RV.Net Open Roads Forum: Tech Issues: solar
 > solar
Henry
Snyder, Texas
Posted: 01/17/21 11:35am Link  |  Quote  |  Print  |  Notify Moderator
I just want to operate a residential fridge thru my inverter. How many 12v batteries and will a 100w panel work?
Henry Holley
Snyder, Texas
2006 Chevy 3500, 6600 DuraMax
2004 Cardinal 33TS
Monterey, California
Posted: 01/17/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
Is your fridge 12 volt or 120 volt? How many amps does the fridge use when running? How efficient is your inverter? How many amp hours will your batteries hold? Are you sure the fridge is all you want the batteries to power? Better approach is to do an energy survey to determine your needs...then times 1.5.
wanderingaimlessly
Buggs Island Lake
A resi fridge will draw upwards of 1000 watts on start up, a smaller unit (10 cuft) may draw a little less, you'll likely need a pair of GC batteries and two 100 watt panels as a minimum, and will not be able do much of anything else from them. and a couple of rainy/cloudy days will likely overtax that. Better to look at 4 batteries, and at least three 100 watt panels and 4 would be better.
A very rough rule of thumb is to try to match watts of solar to amps of battery, ie for a single battery with almost 100 amp hrs capacity to a 100 watt panel.
An audit of your actual usage, and then sizing a system to be 50 to 100% above your indicated usage is preferred to allow for partial shade or overcast conditions.
Posted: 01/17/21 11:58am Link  |  Quote  |  Print  |  Notify Moderator
Henry, a 100 watt solar panel under ideal conditions will produce 5.6 amps per hour...nominal 12 volts. Solar is great but you can’t do much with one 100 watt panel. You need adequate panels, batteries, a controller and large size wire...all based on an energy survey.
ORbiker
Springfield, Oregon
Posted: 01/17/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Henry
We have a residential frig in our Solitude. It will draw a little bit more then 100AH in a day. I put 4 100AH lithium batteries and 4 160W panels on the roof. I should have done at least 6, but I have 200W of portable, so We are ok.
Having the big battery bank I think works well. I have a Honda 2000i for a backup and the lithium batteries charge way faster then wet cell batteries. KEN
Backpacker and tent camper all my life. Motorcycle trips with a tent too 1978 to Present. 2016 Grand Design 380TH as of 10-29-2015. Now a New 2018 374TH-R Solitude as of 3-16-19. 10-19-18-traded truck for a 2016 Ram 3500 DRW Laramie Crew Cab 4x4 Long Box.
Posted: 01/17/21 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Running a residential fridge in an RV while dry camping takes planning.
time2roll
Posted: 01/17/21 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Plenty of reports that have 4 batteries and 500 watts solar still needs a generator at times. You will get more power from your solar with lithium. Solar is good for maybe 5-6 hours a day, fridge runs 24/7.
675w Solar pictures back up
Gdetrailer
PA
Posted: 01/17/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
Actually the fridge will generally on run the compressor 20minutes to 30 minutes per hr so in reality fridge runs 12 hrs or a bit less per 24hr..
Inverter can be an issue but if you have an inverter which has a power save feature you can reduce the amount of energy used by the inverter when it only powers up when there is a AC load demand large enough to turn it on.
For the record, I am only using one pair of 6v GC2 batteries to power my home fridge conversion for 24 hrs between charging..
naturist
Lynchburg, VA
Posted: 01/17/21 03:48pm Link  |  Quote  |  Print  |  Notify Moderator
Not enough information to hazard a guess, IMHO.
pianotuna
Regina, SK, Canada
Posted: 01/17/21 11:01pm Link  |  Quote  |  Print  |  Notify Moderator
Start with an energy audit. Decide how much reserve capacity you want. From that design the battery bank. Build a solar panel system that will recharge the battery bank.
Regards, Don
 > solar
