RV.Net Open Roads Forum: Is this doable or am I overlooking something??
 > Is this doable or am I overlooking something??
wapiticountry
Mountain West
Posted: 01/20/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
Lantley wrote:
I'm not in denial that it doesn't cost the CG more. Hwevrer for the most part these cost are negligible. For every guy running a 2nd codr there is someone staying in a tent or someone gone for the day and using minimal electric.
If electric cost where truly a profit and loss nightmare CG's would go to a metered format. However most do not simply because its not necessary. They set a price a build in a can't lose allowance for electric.
Now I agree there are CG's with wiring issues and CG's that feel they are being taking advantage of that prohibit 2nd cords.
My current rig is 50 amp so I can run a couple of space heaters microwave etc. with no issues.
Occasionally I end up on a 30 amp site, when 50 amp site are unavailable. Many state parks have only 30 amp sites.
In this scenario, I will use a 2nd cord to run my 2nd A/C when required.
I have my A/C wired through a transfer switch that allows me to chose 2nd cord circuit or internal (normal) 50 amp circuit.
When electricity is included in the overnight rates, the owner has factored that into the pricing. 50amp sites are almost always higher priced and one of the big reasons for that is 50amp rigs use more power. Likewise, tent sites are often lower cost.
For an individual renter, $6/night may sound negligible but when you multiply that out over 30 days per month and dozens of sites, it quickly becomes very significant for the owner.
When a park offers electricity (or any other amenity) as inclusive in the price that park has made that decision based on "average" usage. When a renter wants to add additional loads to those amenities beyond normal usage the park may need to place safeguards in their policies and procedures to prevent that from happening.
We learned that lesson the hard way. At our first park, when we were new to the business, we took some winter guests. We did not have metered electric, so we just went with our normal monthly rate. Little did we know that those guests would electrically heat everything. They used space heaters inside their rig. They had heat tape on all their lines. They even placed space heaters under their rigs, open to the outdoor air. They got that additional power by using every available outlet on the pedestal plus ran additional cords to the neighboring pedestals. Our normal in season power bill ran around $100.00 per rented site. That winter the power cost us over $600.00 per rented site. The site rental didn't even cover the power, much less the water, Sewer, cable TV, Wifi, Snow Removal, costs of keeping the restrooms open etc. It ended up being a multi-thousand dollar lesson learned.
Years of experience has taught us that you never know what lurks inside the RV you just rented a site to. It might just be a single space heater that would only add pennies to the power bill. However, it might someone who feels it is fine to run 10 space heaters and leave the windows and doors wide open when it is -10F. Heck, someday it might even be a mobile server farm that is mining for Bitcoins that if given free range will suck up $100s of dollars of power a day.
Charlie D.
E. Texas-Orange
Posted: 01/20/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Check all the connections at breakers and any other wiring connection.
My home is all electric and my heater wstarted tripping.
Thinking I had a bad element I call my AC guy.
First thing he did was tighten all the screws at the breakers including neutrals and grounds.
Solved the problem.
Chum lee
Albuquerque, NM
Posted: 01/20/21 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
valhalla360 wrote:
Chum lee wrote:
If you pay for a 20, 30, or 50 amp unmetered space, (electricity is included in the daily/weekly rate) IMO, you can use all the plugs available at the pedestal in YOUR campsite. You can add additional extension cords, if needed. If the campground owner/manager complains, have them move you to (or charge you for) a larger service/space. (which will, most likely, be more expensive) Do not attempt to argue with with people who do not understand how electricity works. Simply move to another campground.
You have it backwards.
If you are paying a metered rate, as long as all the plugs go thru the meter and it doesn't start popping breakers, use what you want...you will pay for what you use.
For short term non-metered sites, they typically ask what your RV is (30 or 50 amp). Also, if you read the fine print on the rental agreement, it often mentions using additional outlets. So the owner would be very much within their rights to limit usage to a single outlet.
You might get away with it but that doesn't make it right.
Oh for God's sake, IMO, you've never owned a profitable business. So, . . . the "fine print" you've read covers ALL rental agreements? I don't think so. This is just boilerplate for those too lazy/stupid to read/think for themselves and apply it to whats currently "up." Am I encouraging RV'ers to steal from RV Parks? NO. I am not. Just the reverse. In most cases we're talking ignorance and pennies here.
Sure, . . . . you can be right. When I was about twelve years old, (I'm 67 now) I remember reading a biography about Henry Ford. The author mentioned Henry's constant annoyance with his bean counter penny pinching bookkeeper/accountant who knew "the price of everything, but, the value of nothing."
I've respected you to this point. I will no longer read your posts.
Chum lee
* This post was last edited 01/29/21 08:12pm by Chum lee *   View edit history
Chum lee
Albuquerque, NM
Posted: 01/23/21 10:01pm Link  |  Quote  |  Print  |  Notify Moderator
I am truly sorry to read this and, clearly, you have been taken advantage of. (hopefully, only a few times) I assure you, RV'ers, at least where I come from, are generally NOT like this. (IME, some are complete slobs, which is obvious) Others need to be 86'ed immediately. Live and learn. Get some night vision goggles, (infra red and fairly cheap) and patrol the campground daily and at night when its cold out. You'll spot the abusers right away.
Chum lee
Posted: 01/24/21 04:43am Link  |  Quote  |  Print  |  Notify Moderator
When I bought my membership I was driving a 50 amp RV. the sales person promised me "Full Hookups" that's water, sewer, 50 amps and she even mentioned Wi-Fi. Thus I paid for 50 amps. and if the park only has 30's I'm going to use that 2nd cord.
Chum lee
Albuquerque, NM
Posted: 01/29/21 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Well, . . . . you quoted me, and then posted what "others" said, but, . . . . I think I get your point.
Chum lee
dieseltruckdriver
Black Hills of SD
Posted: 01/29/21 11:34pm Link  |  Quote  |  Print  |  Notify Moderator
I also added a seperate outlet for a space heater, and have been accused of cheating/stealing in the past on this site. The fact is, the places I stay that have electric sites don't charge any difference for a 30 amp or a 50 amp rv. My 5er is a 30 amp rv, and my 30 amp with an additional 15 amp cord don't have the ability to use what a 50 amp rv could.
The only reason I do this is I don't trust the cheap receptacles every rv comes with to run a 1500 watt heater. When I use an internal outlet, I only use the heater on low.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
beemerphile1
Ohio
Posted: 01/31/21 03:24pm Link  |  Quote  |  Print  |  Notify Moderator
It can be done and as others have stated - it is done but technically two power sources into one structure is a code violation.
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Chum lee
Albuquerque, NM
Posted: 02/01/21 07:10pm Link  |  Quote  |  Print  |  Notify Moderator
Well, . . . . , that's a pretty broad statement. I'm not sure what local codes you're referencing. You didn't mention any. Have you ever heard of . . . . . SOLAR PANELS on the power grid? (two separate power sources going into the same structure) You need not reply.
Chum lee
