RV.Net Open Roads Forum: Tech Issues: Adding Heat Strips
 > Adding Heat Strips
Loganhorse
Kentucky
Posted: 01/18/21 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
What's the chances of being able to add heat strips to a B57915.711C0 with a control box of 3107541.009. Having a hard time locating anything on it.
2010 Coachman Freedom Express M-291 QBS
craig7h
Branson MO area
Posted: 01/19/21 02:59am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried the mfg of the unit, just to see if its do able
Itasca Meridian SE 36g
Road Master Tow Dolly
Loganhorse
Kentucky
Posted: 01/19/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
I have not, I'm going to call them today. It was too late yesterday.
cavie
Posted: 01/19/21 06:55am Link  |  Quote  |  Print  |  Notify Moderator
If you add heat strips you must add wire and breaker to carry the extra load of the strips. Also, thermostat to control them. Not a DIY job.
Loganhorse
Kentucky
Posted: 01/19/21 07:25am Link  |  Quote  |  Print  |  Notify Moderator
I have not checked to see what size wire is running to the unit.
CA Traveler
The Western States
Posted: 01/19/21 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Ceramic heaters are a much quieter and less expensive solution.
2014 Grand Cherokee Overland
Bob
way2roll
Wilmington NC
Posted: 01/19/21 08:02am Link  |  Quote  |  Print  |  Notify Moderator
I asked about adding heat strips to a former MH and was told that if your current unit isn't wired for it - with a harness, breaker, and thermostat- it wasn't an easy job or worth the time, trouble and money. Plug in ceramic heater will work just as well and be much cheaper and easier. That was sort of what I was thinking at the time and never bothered to research it much further so I ditched the idea.
Loganhorse
Kentucky
Posted: 01/19/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
They sell the thermostat kit and control box according to Dometic. Still have to check wire size
Cummins12V98
on the road
Posted: 01/19/21 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Cheap Heat
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
road-runner
Oregon
Posted: 01/19/21 09:22am Link  |  Quote  |  Print  |  Notify Moderator
I don't understand why. There should already be a 20 amp circuit going to the air conditioner.
2009 Fleetwood Icon
