RV.Net Open Roads Forum: Tech Issues: Adding Heat Strips
 > Adding Heat Strips
dougrainer
Carrolton, Texas
Posted: 01/19/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
cavie wrote:
If you add heat strips you must add wire and breaker to carry the extra load of the strips. Also, thermostat to control them. Not a DIY job.
He has a Dometic roof AC. WHY WOULD HE NEED TO CHANGE THE WIRING OR BREAKER????????????. The system is designed for 20 amp max service. The largest Heat Strip is about 12.1 amps. The AC in COOL/Max fan is about 13.2 amps. The heat strips are plug and play. The only requirements are, that for easiest install you have a wall Tstat and you may have to replace the wall tstat if you have NO Heat Strip option, only furnace. You can add a Heat Strip to a Roof mounted control system but you have to replace the Tstat and possibly the ON/Off knob control. Doug
mobeewan
Hampton, Va
Posted: 01/19/21 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Check the manual or check with domestic. Some A/C units have plastic parts in the area where the heat strip mounts that may melt.
road-runner
Oregon
Posted: 01/19/21 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Dometic makes a kit for the OP's model. I would hope it doesn't melt things.
Dometic heat strip for B57915 ducted system
There's a different kit for non-ducted systems.
Two points from my experience:
1) Don't expect a huge amount of heat. Doug posted the wattage earlier. A space heater can give just as much or more heat.
2) These things stink like heck on the first use of the season. Before you really need it, run it a few minutes with the windows open.
2009 Fleetwood Icon
Sjm9911
New Jersey
Posted: 01/19/21 02:43pm Link  |  Quote  |  Print  |  Notify Moderator
I had them in my pop up ac. They basicly said they were more like warmers to make it a tad more confterble then to be able to give off any real heat. And they were right.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
mobeewan
Hampton, Va
Posted: 01/19/21 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
As I said "Some A/C units". That is the warning that I saw someone post on another forum. As I stated the OP should check to make sure that his unit is okay to add it. If Dometic makes a kit then it should be able to be added without issues as long as the installation directions are followed.
Terryallan
Foothills NC
Posted: 01/19/21 05:22pm Link  |  Quote  |  Print  |  Notify Moderator
Agree. they really aren't worth the effort. In my popup. If it was 60 degrees. The heat strip would warm it right up to 61. Only it would feel colder.
Save your money. Heat strips heat less than a hair dryer.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Lynnmor
Red Lion
Posted: 01/20/21 05:55am Link  |  Quote  |  Print  |  Notify Moderator
Since heat strips put out about the same BTUs as a portable heater they will raise the overall temperature about the same. When people complain about little heat from them, they aren't considering the considerable air flow from the air conditioner fan. The air temperature from the ceiling vents will be much less than from a small portable heater but there will be much more air. That flow of air that is only a few degrees above the ambient air temperature may feel cool, but just leave it on. As the temperature rises it won't feel so cool when near normal room temperature.
way2roll
Wilmington NC
Posted: 01/20/21 06:19am Link  |  Quote  |  Print  |  Notify Moderator
But to this point it begs the question - why bother? Given that it's considerably more cost and effort than a few ceramic heaters that produce the same result. Personally I wouldn't want to put the time and effort into a heating system that still leaves me feeling cold. I don't think I've ever read anything on this forum over the years that say that heat strips are awesome. Almost invariably, all posts agree, they marginally work if it's not really cold to begin with.
Lynnmor
Red Lion
Posted: 01/20/21 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Because the cost is quite low, they don't need to be stored, they are always ready to go and a thermostat controls them. I have never seen anyone give them a chance to work, only instant gratification comments.
way2roll
Wilmington NC
Posted: 01/20/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
To each his own I guess. I think heat strips are about $100 when it's all said and done and a small cube heater with the same BTU can be had for about $20. Heat rises, so a portable heater has the advantage of heating from the floor up, as opposed to the heat strips being fan driven with cool air from the top down. I hear you on giving them a chance to work and that makes sense, but when I am cold that's the one time I would prefer instant gratification. I use my LP furnace or fireplace and forget portable units and heat strips altogether. But that's me.
