RV.Net Open Roads Forum: Tech Issues: Adding Heat Strips
 > Adding Heat Strips
Terryallan
Foothills NC
Posted: 01/21/21 06:04pm Link  |  Quote  |  Print  |  Notify Moderator
Lynnmor wrote:
way2roll wrote:
But to this point it begs the question - why bother? Given that it's considerably more cost and effort than a few ceramic heaters that produce the same result. Personally I wouldn't want to put the time and effort into a heating system that still leaves me feeling cold. I don't think I've ever read anything on this forum over the years that say that heat strips are awesome. Almost invariably, all posts agree, they marginally work if it's not really cold to begin with.
Because the cost is quite low, they don't need to be stored, they are always ready to go and a thermostat controls them. I have never seen anyone give them a chance to work, only instant gratification comments.
I gave mine lots of time to work. I turned it on, left it on for a few hours, and when I returned. The pup was just as cold as when I left it. NOT worth the time and money. As I said. they put out about the same heat as a hair dryer, only with more air.. a oil filled heater works MUCH better, and less than $50.00
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Lynnmor
Red Lion
Posted: 01/21/21 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
An oil filled heater puts out 5120 BTU, my $50 heat strip puts out 6000 BTU.
PatJ
Eastern WA
Posted: 01/21/21 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
I added a heat strip to my 2019 Coleman roof AC and in my opinion it was totally worth it. Was a very simple plug and play install, the wiring was all there already from the factory. If you have a newer rig you don't need to mess with wiring or breakers or any of that, it is a simple plug-and-play to existing wiring/plugs with stupid-simple instructions and will work with your existing thermostat. It does not blow out "hot" air to the touch, but if it runs for a short while your rig will be warmer. If we have hookups, we use it as our only source of heat down to roughly 40f OSA and it easily maintains that temp.
In my opinion it is superior to portable electric heaters (which we carry in case of emergencies) because it is the same heat power yet it works with the existing hard-mount thermostats. Also, we often ran our roof air fan at night for background noise anyway, so adding heat was a no brainer. Just my experience. It works great for us.
Patrick
Rick Jay
Greater Springfield area, MA
Posted: 01/22/21 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
Loganhorse,
Every time this comes up we always get the same range of responses, which at first seems to be unhelpful.
For those who say they don't notice ANY difference when their heatstrips are "on", I wonder if they ever checked their system to make sure they were actually wired up correctly. Even from the factory, the techs could mess up and not plug in the heater element. I just don't see how you can have roughly 1200 watts of heat added to an air stream and there be NO apparent change in the temperature. Something is amiss somewhere.
My experience. We have a 36' motorhome and we have two A/C's, and we ordered it so that both units had heat strips. I've used my heatstrips EXTENSIVELY over the years.
They work very well for taking a slight chill out of the air, but they DO work slowly. Our A/C's are ducted as well, so there's a nice distribution of the air throughout the rig. They have saved me LOTS in propane usage over the years. Floor and space heaters are an option, and we used them to supplement the heat strips, usually at night. We always had kids and dogs in the RV with us, and portable heaters get in the way and tend to be knocked over.
We have even used the furnace (controlled by our forward thermostat) in combination with the heat-strips in our rear A/C unit. With the ducted system, this did a great job of distributing the air while also saving a bit on the propane.
Our rig is pretty well insulated (dual pane windows), and I think the quality of insulation on a rig has a lot to do with it, as well.
I posted a long post several years back relating some of our experience with them. I'll see if I can find that thread and add the link here. On edit: I found these....but not the one I was looking for...maybe it was too long ago! Hopefully these will help.
Thread One...
Thread Two...
Thread Three...
...just found Thread Four.
We use the heat strips while travelling in the motorhome in the late Fall, Winter & early Spring along with the dash heat to keep everyone comfy. Before we pull over for the evening, we'll turn on the rear heat-strips an hour or so before stopping so the entire rig will be comfy and ready for us to get to bed.
I'd recommend that you do it. I think the convenience is well worth it. After you do, though, please come back to this thread and let us know how it worked out for you. [emoticon]
~Rick
2005 Georgie Boy Cruise Master 3625 DS on a Workhorse W-22
Rick, Gail, 1 girl (24-Angel since 2008), 1 girl (19), 2 boys (20 & 17).
2001 Honda Odyssey, Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
