RV.Net Open Roads Forum: Class A Motorhomes: Tv problem
 > Tv problem
rgatijnet1
Posted: 01/22/21 06:17am Link  |  Quote  |  Print  |  Notify Moderator
A snowy picture can be from a poor cable connection. Perhaps there is a way to hook up a jumper coax cable directly from the antenna to the TV to see if that gives a clear picture. If it does, than the problem exists in your old coax cable from the antenna to the TV.
oldave
Tx
Posted: 01/22/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Terminology is a little different over here. By aerial are you referring to
an antenna, which is what we use to receive regular tv stations?
I suppose an oyster dish and sky box is a satellite system.
This rear tv, is it hooked to the satellite or to an antenna?
I keep a length of coax cable ( 50 ft ) which we can purchase at Wal-mart.
If you temporarily substitute a long coax by just running it along the
floor to see if it cures the snowy picture.
 > Tv problem
