RV.Net Open Roads Forum: Tech Issues: FLEXIBLE FRESH WATER HOSE
 > FLEXIBLE FRESH WATER HOSE
Page of 5
Posted: 01/20/21 04:37am Link  |  Quote  |  Print  |  Notify Moderator
I recommend AGAINST the expanding hoses as if the park should lose pressure they can pull the connector right off your Rig (major mess. easy repair but major mess)
Ever see those steel wrapped hoses... Dollar Generous.. er. general sells them .
I have one. Easy to wrangle. AND it seems not to mind being run over.
It was suggested to me by a fellow RVer and I used one for about 3 years before the Rig got totaled (Nothing to do with the hose) still have the hose.
rav
Full Timing
Posted: 01/20/21 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Just purchased a flexzilla hose and so far pleased with it, seems to be extremely flexible. We full time so I will see how it holds up.
Sjm9911
New Jersey
The zero g isnt an expandable hose. It just has a collapsible jacket.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
hypoxia
Arizona
Posted: 01/20/21 06:54am Link  |  Quote  |  Print  |  Notify Moderator
My brother had 30 or 40 Flexzilla hoses on the farm. He had so many problems he threw them all away.
Jim
2007 Monaco Signature Noble III ISX 600HP
rhagfo
Portland, OR
Posted: 01/20/21 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Ed_Gee wrote:
Can't get any better than this one. Can't kink, ultra light, more flexible than you can imagine....stores in a compact wad if you dont wind it up in a loop....and I swear it is self draining. Don't be cheap and turn away from this one. ... just look at its ratings....
Apex Zero G hose
I will quote this first of many if you want a great hose at a reasonable cost zero-g. They are great hoses.
ford truck guy
Pennsylvania
Posted: 01/20/21 07:33am Link  |  Quote  |  Print  |  Notify Moderator
I just got my FIRST Zero G hose, have not tried it yet...
There were some on here a few months back questioning if they would work under constant pressure.. I sent an email to the company and received this response -
"Hi Joe,
Thank you for your inquiry. If you have the hose hooked up to an RV and are using a pressure regulator with it, it will work there is notice on the label that the hose is not meant to be left under pressure while unattended but in this application there is an exception.
Stephanie Fontaine
Sfontaine@teknorapex.com
Senior Hose Customer Service Representative
1-800-289-6786 ext 3419 Direct Line : 1-401-642-3419"
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Dutch_12078
Winters south, summers north
Posted: 01/20/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
What kind of problems did he have with them? Mine have been in trouble free daily use for about a year so far.
Dutch
2001 GBM Landau 34' Class A
ferndaleflyer
everywhere
Posted: 01/20/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
I have 2 brand new Camco hoses sitting in the junk pile. Can't even get someone to steal them----stiff as a board. Got one of those collapsible hoses and so far it has worked fine. took a long time for an alternate to show up
valhalla360
No paticular place.
Posted: 01/20/21 08:00am Link  |  Quote  |  Print  |  Notify Moderator
I assume since you seem to be putting it away regularly, it's to fill the tank. Get one of the collapsible hoses. We have one that's about 10-12yrs old and works just fine. Very light, self drains and can be crammed into a very small area. A 50ft hose is easier to manage than a 25ft standard hose.
Now if you are hooking up to the city water connection I wouldn't recommend it. The people we've talked to who've done that found the outer casing degrades in the UV and it fails pretty quickly.
PS: if you are doing city water connection, I would worry more about being FDA approved for drinking water as it will sit baking in the sun with stagnant water in it. Since we fill the tank, the water isn't in contact with the hose for any significant length of time and doesn't have a chance to heat up.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
learntorv
Fulltimer
Posted: 01/20/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
edatlanta wrote:
I wonder how long the Zero G hose will last in full time use?
Just fine. I want to say that mine were 2-3 years old when we stopped fulltiming. Hoses were fine.
Page of 5
