RV.Net Open Roads Forum: Tech Issues: Crummy headlights - Can't see, need upgrade
 > Crummy headlights - Can't see, need upgrade
Page of 7
BobsYourUncle
Calgary Alberta Canada
Posted: 01/19/21 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
My old 2007 GMC has never had the best headlights.
Driving from Lethbridge to Calgary last night I was really cussing them.
Old original factory headlights and I cannot see worth a darn. They are so lame that I deem them unsafe.
I have tried different bulbs in them over the years but no real joy there either. One side is a repro unit from a major collision repair in 2012. It is so yellow and dull that I can see a huge difference in the 2.
Anyhow, enough of that....
I am looking for ideas on some decent aftermarket lighting, including the headlight housings themselves. I really like the lights on the newer vehicles, they look great.
I just want to see in safety without blinding oncoming traffic.
Back in the days of my youth we would just replace the sealed beams with Cibies, Bosch or Wipacs. Can't do that today.
Anyone done a complete upgrade kit to their headlights? I'd like to go with LED, so I don't have to put in heavy duty drivers and such. I don't know a lot about them.
I gotta fix this thing, it's terrible.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
enblethen
Moses Lake, WA
Posted: 01/19/21 08:42pm Link  |  Quote  |  Print  |  Notify Moderator
I would be looking on Ebay
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BurbMan
Islip, Long Island
Posted: 01/19/21 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
Bob, I had great luck with an HID kit from The RetroFit Source. I disassembled the plastic headlight assemblies on my 2002 Grand Prix and converted them to HIDs, WOW what a difference.
You can see the projectors inside the OEM housing here:
TRS sells a kit specifically for 07 GMs, and they also have plug-n-play Alpharex Pro lights.
All of these options are kinda pricey but well worth it IMO, especially if you tow at night.
SOLD: 2008 Terry 34' TT
SOLD: 2001 K2500LT 8.1L Suburban
Lance 811 Renovation Story!
Project Complete!
Maiden Voyage!
Gdetrailer
PA
Posted: 01/19/21 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
First and foremost, measure the voltage AT THE BULB!
If your GM is as bad as Fords headlights one the the best upgrades you can do is bypass the OEM wiring with a relay kit.
OEM wiring is barely up to the task, often they will use 18 ga wire to the headlights and when you add up the wire length by the time the voltage reaches the headlights the bulb is only getting about 11V!
You can buy or built your own headlight relay kit, I have made my own using $2.00 30A Bosch relays and 10 ga wire (relay kit goes under hood near battery and you can get replacement harness repair parts to make it plug and play setup.. Plug the input of the relays into one of the headlight connections and the outputs of the relays to your headlights.. connect relay kit to 12V power and ground and now you have full battery voltage.. Basically about 25% improvement in brightness.
I would recommend avoiding LED replacement bulbs in any OEM style or aftermarket housing, quality is spotty at best, some have fans that will eventually fail, some the drivers make a lot of Radio interference and worst of all, LEDs cannot fully simulate the position of the filament making getting a good pattern that doesn't blind on coming traffic difficult to impossible.
Not to mention typically those LED retrofits use LEDs in blueish color temps of 6,000K-6,500K which results in harsh shadows and depending on your eyesight may make your vision even more difficult.
Try building headlight relay kit first, if that doesn't work well, add on an aux driving lights or fog lights (that is what I did for my 97 Ford BEFORE I figured out the headlight bulbs were not getting full battery voltage), those lights were like using a candle)..
BobsYourUncle
Posted: 01/19/21 09:04pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the links, Excellent site. I really like what they have to offer.
Unfortunately, mine is a 2007 Classic, different from the 2007-13..
I changed the application to reflect that and they don't have the headlights for mine. Darn!!! Lots of bulbs though, great selection.
Looks great on your Grand Prix!
BobsYourUncle
Posted: 01/19/21 09:12pm Link  |  Quote  |  Print  |  Notify Moderator
That's a great tip, thanks. I never thought about checking the voltage at the lights. I do recall looking at the size of the wiring once, thinking to myself it looked a little on the lame side.
I used to put relays, do the wiring and put aircraft landing lights on my old vehicles. Boy did those ever poke a hole into the night!
Illegal though, got busted a couple times so I stopped using them......
BobsYourUncle
Posted: 01/19/21 09:16pm Link  |  Quote  |  Print  |  Notify Moderator
Some of those look nice too, thanks.
I wonder if they are made from the same plastic as the aftermarket assemblies. The one I have on mine is really clouded badly.
I guess it's hard to tell what they are made of.
My one OEM headlight is still nice and clear.
1320Fastback
Vista, Ca
Posted: 01/19/21 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
A simple pre built plug and play Dual Relay Harness will improve them 50%. Your likely not getting full voltage to the bulbs if running stock wiring.
1992 D250 Cummins 5psd
2005 Forest River T26 Toy Hauler
Lynnmor
Red Lion
Posted: 01/20/21 05:42am Link  |  Quote  |  Print  |  Notify Moderator
My headlights got much brighter recently, right after cataract surgery.
ford truck guy
Pennsylvania
Bob...
Upgrade to a 2020.. the Ford's headlights were pure TURD.... I love the new LED's in the new trucks ! ! ! [emoticon]
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Page of 7
