RV.Net Open Roads Forum: Tearing down an RV safely
deltabravo
Spokane, WA
Posted: 01/21/21 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
Also, if the frame is good, I'm making a flatbed out of it.
But you said the frame is rotten...
swimmer_spe wrote:
This spring, I will be taking apart a 1975 trailer that the frame is rotten and may not even survive the winter.
swimmer_spe
Sudbury, Ontario, Canada
Posted: 01/21/21 09:43pm Link  |  Quote  |  Print  |  Notify Moderator
The 2 frame rails that run the length of the trailer are solid. The bumper could be pulled off by hand. The rest, I don't know. The reason for it not surviving the winter is the fact that the wood frame is what is really rotten. If we get a good snow load, it will come down. If I am not careful on the roads, it might come down.
Besides, ripping it apart, I can get money for the scrap, whereas bringing it to the dump, I'll need to pay for it.
BobsYourUncle
Calgary Alberta Canada
Posted: 01/21/21 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
I still like my Free ad!
[emoticon][emoticon]
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
swimmer_spe
Posted: 01/24/21 09:30pm Link  |  Quote  |  Print  |  Notify Moderator
GDS-3950BH wrote:
swimmer_spe wrote:
If I take it tot he dump, it'll cost me more than tearing it apart and taking the pieces to the dump. Also, if the frame is good, I'm making a flatbed out of it.
Rent a small excavator for a weekend, dig a large hole, then use the machine to rip the structure from the frame. Bury the metal, burn the remainder.
Mostly a waste of time and money as the frame will probably need a lot of reinforcement added to be used as a cargo or utility trailer, and the axle capacity will most likely not cover its repurposed use after conversion. A deck substantial enough to use will weigh as much as the box you ripped off the top. It would be cheaper to buy one designed for the intended purpose.
Around here local auto salvage or scrap yards will take them free, some will even pay you for them.
I'll likely spend about $1k on the project. A new trailer that matches my needs would easily cost $5k. If the frame is not worth keeping, then I will look at going to a new trailer.
coolmom42
Middle Tennessee
Posted: 01/25/21 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
swimmer_spe wrote:
DrewE wrote:
The main energy source remaining is gravity. Pay attention to that and all should be well.
That is the biggest one that worries me. My hope is to be able to direct those forces in a controlled manner.
A hard hat might be your friend. Not a bump cap, a real hard hat with an internal shock absorbing suspension.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
Matt_Colie
Southeast Michigan
Posted: 01/27/21 10:02am Link  |  Quote  |  Print  |  Notify Moderator
Swimmer,
The most dangerous thing (after the millions of staples) is that the structure may collapse on you when things are removed. To date, I have three friends that got injured this way. One of these even collapsed with the rear wall still in place. The other two had both ends open. One had been braced by a pair of 2*4s in the middle, but someone kicked one loose and down it went.
All these cases, be sure to have a camera man, you could get the 10,000$ on America's stupidest people....
Sorry, you are in Sudbury, well maybe there is Canadian version.
Whatever, just keep thinking what can go wrong.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
swimmer_spe
Posted: 01/27/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
Matt_Colie wrote:
Swimmer,
Matt
Once the stuff besides structure is removed from in the trailer, it will be taken down from the outside.
Foggy
Kalamazoo Mi. U.S.A.
Posted: 01/30/21 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Strip the inside. Remove the outer skin and insulation. Add a lit match. There shouldn't be enough heat from what little wood is in the framing to warp the steel frame.
Happy-Trails
Foggy
swimmer_spe
Posted: 01/30/21 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
I don't have a big enough clearing to do the last part....
BobsYourUncle
Posted: 01/30/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Invite all the local teenagers.
Tell then you have a case of beer that says they cannot have this thing on the ground in pieces inside an hour.
