RV.Net Open Roads Forum: Tow Vehicles: Build my TV
Search only in Tow Vehicles
 > Build my TV
Page of 7
bc-00044
denver, CO
Posted: 01/21/21 08:59am Link  |  Quote  |  Print  |  Notify Moderator
Upgrading from a 27'TT to a 41' 5er. Obviously now also need to trade in my TV for something more capable.
Relying on the collective wisdom of this group for guidance. I do not have any strong brand loyalty beyond american made -- concerned about driving experience, ride comfort, towing capacity for the quoted trailer, and reliability. Make your proposals.
Pretty well set on a diesel, but convince me if I am wrong.
Trailer is 40' UVW 14344 lbs
Dadoffourgirls
China, MI USA
Posted: 01/21/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
2021 Sierra Denali 3500 Crew cab with Duramax dual-rear wheels, with Technology package, gooseneck / 5th wheel prep, trailer tire pressure monitor sensors. Assembled in Flint, MI.
Dad of Four Girls
Wife
Employee of GM, all opinions are my own!
2017 Express Ext 3500 (Code named "BIGGER ED" by daughters)
2011 Jayco Jayflight G2 32BHDS
Cambria, California area
Posted: 01/21/21 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Any of the big three one ton dual rear wheels will work.
Cummins12V98
on the road
Posted: 01/21/21 09:53am Link  |  Quote  |  Print  |  Notify Moderator
RAM HD's are "Assembled" in Mexico with mostly US Made components.
Ford's Diesel is Made In Mexico.
Guess you need to look into GM's total content.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
p220sigman
Tallahassee, FL, USA
Posted: 01/21/21 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Only you can decide since most of your requirements are subjective. Any of the big 3's 3500/350 series DRW diesels will work. I'd decide on which options aren't "optional" and drive each one. I don't think you can go wrong with any of them as far as reliability goes.
goducks10
There
Posted: 01/21/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
100% go diesel. DRW vs SRW is TBD. I'd go DRW FWIW.
Any of today's diesels will tow that size 5er all day without breaking a sweat.
Whats different is the interiors and the ride.
Best to drive all 3 on a long drive vs the short route dealers like to take you on.
MFL
Midwest
Posted: 01/21/21 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Right now, the GM with Duramax is a great choice! Either of the others, a good choice, the Mexican made/assembled, not really an issue IMO.
Jerry
Sjm9911
New Jersey
Posted: 01/21/21 11:17am Link  |  Quote  |  Print  |  Notify Moderator
Why go small with the 1 tons? If your going to go big, go big.
https://fifthwheelst.com/heavy_duty_trucks_hdt_towing_rv.html
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
valhalla360
No paticular place.
Posted: 01/21/21 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
What's the GVWR...I would guess 17-18k. (empty weight is pointless as you aren't going to travel with an empty trailer) That suggests a pin weight of 3500-4000lb. Is it a toy hauler? Those often have pretty large payload capacities.
Even at the lower end, you are in 1 ton dually minimum territory and being from Denver, the high altitude advantage of a turbo along with exhaust braking recommends a diesel.
Any late model will do the trick. (10-15yr old trucks may not be capable but it sounds like you are going new, so that may not be relevant)
You might also want to look into some of the 450/4500 models but the line has gotten blurry with the 1 ton capabilities climbing substantially.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
bc-00044
denver, CO
Posted: 01/21/21 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Should have added more detail. GVWR = 16,800# Hitch weight 2686#
Very interested in the comments on DRW v SRW
Page of 7
 > Build my TV
