RV.Net Open Roads Forum: Tech Issues: Installing Solar
 > Installing Solar
1L243
Oregon
Posted: 01/21/21 10:47pm Link  |  Quote  |  Print  |  Notify Moderator
My 500 watt system of 5 panels will be on order soon. I have watched several install videos, almost all videos show the installer mounting the solar panel brackets by screwing into the roof. Only one made any mention of looking for trusses to screw into. My roof has 3/8" plywood sheathing. Is it necessary to find a truss or is screwing in the sheathing acceptable? Panels can be placed more precisely if you don't have to hit a roof truss.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
2oldman
NM
Posted: 01/22/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
You'll be fine with that.
#1Flyboy
California
Posted: 01/22/21 07:18am Link  |  Quote  |  Print  |  Notify Moderator
.... I’ve read where some people have used something like Dicor or Liquid Nails between the roof & mounting brackets.....
jshupe
FT
Posted: 01/22/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
You will be fine screwing into 3/8" ply. The usual procedure for a 3/8" ply with a rubber membrane is to use 3M 4200, Chemlink M1, or Dicor between the roof and the Z bracket, use #14-1" stainless pan head screws, glob some sealant on top of the screws, and not worry about them going anywhere.
2019 Ram 3500 HO/AISIN CCLB DRW Longhorn
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
CA Traveler
The Western States
Posted: 01/22/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
I don't recommend Z brackets because of the difficulty of panel removal if needed. Instead use 2 pieces of aluminum angle bolted together to form a Z, easy to remove panel.
2014 Grand Cherokee Overland
Bob
Lake Crowley area, California
Posted: 01/22/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
My panels are screwed into 3/8 plywood. Four+ years now with no issues.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-parallel & MPPT, Trojan T-125s. TALL flag pole. Prefer USFS, COE, BLM, NPS, TVA, state & county camps. Bicyclist! 14 year Army vet-11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Jay58
Melbourne (central east coast) Florida
Posted: 01/22/21 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Mine are screwed into 3/8 plywood thru a 6 inch long aluminum angle 2x2 with 5200 sealant/adhesive to glue down and seal fastener holes. Wires were attached to roof with eterna-bond tape ( no screw required)
2020 Jayco Precept 34G
Central Florida (East Coast)
jshupe
FT
Posted: 01/22/21 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
No plans to ever remove them!
Posted: 01/22/21 04:31pm Link  |  Quote  |  Print  |  Notify Moderator
I agree, JS. Break in the glass would be the only reason.
pianotuna
Regina, SK, Canada
Posted: 01/22/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Jshupe,
Mine are aluminum angle screwed to the roof. I used just 3 screws per side. They are still in place.
Regards, Don
 > Installing Solar
