time2roll
I used #10 stainless drywall screw and Dicor just into the plywood at random.
I did drill a small pilot hole so the screw would penetrate cleanly.
edited 01/22/21 09:13pm by time2roll *
675w Solar pictures back up
jshupe
FT
pianotuna wrote: Jshupe,
Mine are aluminum angle screwed to the roof. I used just 3 screws per side. They are still in place.
No issue with that. I've used 2x2 aluminum angle screwed to the roof (with sealant, as I'm sure you're using) as well.
Did I miss something - why are you telling me specifically?
Edit - if it was due to my quoting Jay58, I was referencing his use of 3M 5200. It forms a permanent bond that will tear the rubber and plys apart before it gives. Wonderful stuff - for use under the waterline on a boat.
2019 Ram 3500 HO/AISIN CCLB DRW Longhorn
2020 Jeep Wrangler Unlimited Rubicon 2.0T (follow or TC toad)
2015 Keystone Alpine 3730FB 2925W/22.8kWh, 30K multi-split
2016 Arctic Fox 1140 WB 1800W/11.4kWh
BFL13
Victoria, BC
jshupe wrote: Jay58 wrote: Mine are screwed into 3/8 plywood thru a 6 inch long aluminum angle 2x2 with 5200 sealant/adhesive to glue down and seal fastener holes. Wires were attached to roof with eterna-bond tape ( no screw required)
No plans to ever remove them!
Not until you have to when trouble shooting the wiring some day! It can happen the trouble is underneath by the junctions that you can't get at with the panel in place.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
jshupe
FT
BFL13 wrote: jshupe wrote: Jay58 wrote: Mine are screwed into 3/8 plywood thru a 6 inch long aluminum angle 2x2 with 5200 sealant/adhesive to glue down and seal fastener holes. Wires were attached to roof with eterna-bond tape ( no screw required)
Again, I was taking a jab at the 3M 5200 that Jay58 used. It's a permanent bond that would tear apart the rubber roof and plywood before it would ever give. It's mostly used for bonding under the water line on boats and will rip apart a fiberglass hull before it fails. I used plenty of it on my offshore boat.
BFL13
Victoria, BC
Meanwhile, I was taking a jab at the idea of Z brackets. I agree with using two pieces so you can get the panel off and leave the bottom bracket still attached to the roof. Hope the OP figures it all out!
1L243
Oregon
The problem is finding aluminum L brackets. The Z brackets are easy to find L brackets not so easy.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
time2roll
Can't you just get some L aluminum stock at Home Depot etc. and cut and drill as needed?
https://www.metalsdepot.com/aluminum-products/aluminum-angle-6061
1L243
Oregon
I found that Renogy sell a adjustable two piece L bracket.
https://www.amazon.com/Renogy-Solar-Mounting-Curved-Bracket/dp/B0751T3QV6
Think I will use these
2oldman
NM
You don't plan on tilting these panels?
CA Traveler
The Western States
1L243 wrote: The problem is finding aluminum L brackets. The Z brackets are easy to find L brackets not so easy. Just the opposite as HD, Lowes and hardware stores carry aluminum angle. Very easy to cut and drill.
2014 Grand Cherokee Overland
Bob
