RV.Net Open Roads Forum: Ford 6.2 gas vs 7.3 gas highway gas milage
 > Ford 6.2 gas vs 7.3 gas highway gas milage
Page of 6
Kayteg1
California > Nevada
Posted: 01/25/21 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
jimh425 wrote:
99 is the mpg for all Fords I’ve been in. You only have to hit reset and go down a steep hill. It’s the norm. [emoticon]
You have a picture to prove it?
I have 1 for my sedan.
Bad news, 99.9 is end of the scale as for some time I was doing much better.
[image]Click For Full-Size Image.
Posted: 01/26/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Highway Runner wrote:
I am running the 6.2 Dually with a 4.30 axle. I am able to stay right around 10 mpg. The axle gear has something to do with mpg. The bigger the number, the lesser the mpg. Like one guy said, I didn’t buy mine for mpg, I wanted better pull going up hill.
Having run a lot of miles in 6.2 Fords. F250s, I can say your mileage is NOT the norm and either your reporting is, umm, optimistic, or you are basically hyper miling the truck.
Presume you’re saying 10 mpg with a big truck camper on. 10-12mpg sounds right driving empty.
Again, unless you have a bumper sticker that says “55 saves lives” and actually believe it!
2017 Heartland Torque T29
jsc253
Orange County, CA
Posted: 01/26/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2016 F250 with the 6.2 gasser with 3:73 and hall a Northstar TC650 pop up truck camper. On the highway at reasonable speeds, I get between 11-12mpg. In town, it is less. The performance is fine but mileage with truck campers is never good!
noteven
Turtle Island
Posted: 01/28/21 06:04am Link  |  Quote  |  Print  |  Notify Moderator
flyte63 wrote:
Anyone have real world HIGHWAY gas milage figures for a Ford Super Duty with about 3000lbs of truck camper in the bed? I’m specifically wondering about 2017-2021 F250 and F350 trucks with the 6.2 gas and new 7.3 gas engines. Reading online I see claims of similar or maybe only 1mpg less with the new 7.3 gas engine, but what about in the real world? (I know they have their place, but not interested Diesel numbers)
My 2012 6.2 gas flatbed 4x4 Fordor Ford at 100000 miles does 8-10 mpUSgal campering and 14-15 mpUSgal bob tail. Towing a 16 x 8-1/2ft tandem enclosed doesn't change it much except when the crosswind blows. Then 7 is totally achievable.
jaycocreek
Idaho
Posted: 01/28/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
These MPG threads are totally dependant on the driver and his habits..There are some here that could make a VW Beetle get bad mileage.LOL
My last two 7.5 Fords(460) have both gotten 10mpg+ loaded ready to camp because I know I have a zippy/gas guzzlin' engine if I do not keep my foot out of it..I easily get 13+(never 14 yet) empty and 10+ with the TC on and the other was a Class C..LOL
I would not hesitate to get either of Fords engines or the Chevy 6.0 like my son has that's been bullet proof..
billtex
RI
Posted: 01/28/21 11:10am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind all the F350 are ten speed as of 2020. So comparing 2017-2019 to 2020+ will be slightly different with ten speed having the advantage.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
Kayteg1
California > Nevada
Posted: 01/28/21 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
I guess 10 speed can help in city and mountain driving.
My dually spend about 95% of its life on the highest gear and highest gear usually is the same regardless how many other gears you have.
egarant
Mission Viejo CA
Posted: 02/02/21 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
I will be picking up a new 2021 Ford F-350 dually 4x4 in less than two weeks.
It will have the 7.3 gas with 4.30 rear end. I will be putting an 2013 Eagle Cap 950 on it.
I is too bad, and always the case, that aftermarket shocks/sway-bars are not available this early in the model year.
I will update the forum as to how this truck performs.
This truck will be replacing a 2013 RAM 3500 4x4 dually.
2021 FORD F350 dually 4x4 with 4.30 gears
2013 Eagle Cap 950
480 Watts Solar, 2K Watt Xantrex Inverter, Reonogy MPPT Charge Controller, 250 amps of lithium batteries by LifeBlue
billtex
RI
Posted: 02/02/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
Sweet. I doubt you will need any suspension mods. Payload on that truck is crazy! Of all the mods I have done, sway bar was the least effective. You should be fine.
hedge
Airdrie, Alberta, Canada
Posted: 02/02/21 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
There are no changes from 2020 to 2021 so should be easy to find aftermarket parts. I wouldn't expect that you'd need any mods for that camper.
I also recently went to a 7.3 gas after owning diesels for ~12 years, mine's a single wheel with the Tremor package. Haven't had the camper on it yet. Don't really expect great gas mileage but not really a factor in my decision to go gas.
2017 F350 Platinum DRW
2013 Adventurer 89RB
Page of 6
