RV.Net Open Roads Forum: Truck Campers: Max Payload Question
 > Max Payload Question
moonlitsouls
Everywhere
Posted: 01/23/21 04:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hope all is well ,
Setup:
2006 Ford F-350 Super Duty Lariat Crew Cab LB 4WD + 2019 Eagle Cap 811
the dry weight of my camper is 3350
the max payload of my truck is 4300
Unladen weight is 7000lb
MVWR of the truck is 11500
BUT the max payload of the tire is 3640 x 4 = 14560
thoughts? i want to make sure im not going to be pushing it too close
thanks
* This post was edited 01/23/21 05:04pm by moonlitsouls *
Buzzcut1
Norcal
Posted: 01/23/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
If you are going by the sticker on the camper you are in for a shock. Those are notoriously low by 500- or more pounds. I would suggest going to a CAT Scale and weighing the rig then looking at the load rating of your tires
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
K Mac
Lower Hudson Valley N.Y.
You're already over your max, but you don't know it. What does your set-up consist of ?
moonlitsouls
Everywhere
Posted: 01/23/21 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
interesting , i added some important notes to the main body of the initial post , let me know what you think about the tires. thanks a lot
moonlitsouls
Everywhere
Posted: 01/23/21 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
So the dry weight is not correct? They should not be doing that
billtex
RI
Posted: 01/23/21 05:35pm Link  |  Quote  |  Print  |  Notify Moderator
moonlitsouls wrote:
Hope all is well ,
Setup:
thanks
All of the TC weight will be on rear axle. So it is more like 3640x 2= 7280-rear axle weight of empty truck. This will be your available payload.
Is truck gas or diesel?
If gas you should be ok once you upgrade tires. You can get LR129 tires rated at 4080 (x2= 8160#).
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
Near DVNP, California
Posted: 01/23/21 05:39pm Link  |  Quote  |  Print  |  Notify Moderator
Weigh the camper. Don’t go by stickers.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
specta
utah
Posted: 01/23/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Brochure weight for my camper is 2826 lbs.
Fully loaded for camping it weighs 3960 lbs.
It takes 100 lbs off my front axle.
Rear axle empty, 2900 lbs. With camper, 6960 lbs.
* This post was edited 01/24/21 06:45am by specta *
Kenny
2011 Chevy 2500 HD 6.0L 4wd
moonlitsouls
Everywhere
Posted: 01/23/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
thanks guys , i already got myself a firestone ride right air kit , i wonder if upgrading the real leaf springs would also be good?
Anyone heard of General Spring leaf spring company?
JIMNLIN
Oklahoma
Posted: 01/23/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Is the 3640 lb per tire for a single or dual application.
Dual application for a DRW truck is the smaller capacity.
Your '06 F350 DRW probably has a 9000 RAWR. That year model trucks rear axle may weigh in the 3400-3500 lbs range which leaves the truck with around 5500 lbs for a in the bed payload.
