RV.Net Open Roads Forum: Travel Trailers: tandem axle channel supports
 > tandem axle channel supports
grampyjd
home
Posted: 01/25/21 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to each and everyone of you. I learned a lot. I did not notice the missing rubber boots for the brake adjustment. Should have known I adjusted a lot of brakes back in the sixties. I had no idea that there would be rubber inside the axle tube. Wow this old dog needs to do more reading.
Thanks a million everyone.
Sincerely,
grampyjd
jstouffer@stouffertech.com
Huntindog
Phoenix AZ
Posted: 01/26/21 03:21am Link  |  Quote  |  Print  |  Notify Moderator
Yeah, it is basically a rubber spring system. There are a few different versions of such suspensions out there.
Like everything, there are pros and cons.
Pros: Independant suspension and a lower ride height. Pretty much maintainence free, for quite a while.
Cons: Lower ride height. (yes this can be good or bad)The rubber will eventually break down. Rubber ages even when not being used. Some use is good, as it keeps it limbered up (so to speak) too much use will accellerate the wear. There is a sweet spot in there somewhere for maximum life... Just cannot tell where it is. When the rubber deteriorates, the cheap fix is to have the setup reclocked. But this doesn't have a good track record. The old rubber is still in there, so it just doesn't hold the adjustment well. The rubber can be replaced, but this can cost almost as much as new axles. There really isn't a cheap repair on this system as there often is with traditional suspension.
Not making a recomendation either way. Your money, your choice
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1380watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
djsamuel
Central Florida
Posted: 01/26/21 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
grampyjd wrote:
Thank you for the info. Here is the photo I wanted to show. The formed steel angle looks some what light for twisting and turning the travel trailer
Looks very similar to my camper with similar axles. No problems over 7 years.
Picture of Our Trailer
Camplite 21BHS
