RV.Net Open Roads Forum: Tech Issues: Drip
 > Drip
Mike P.
Des Moines, Iowa
Posted: 01/24/21 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I have a small drip coming from the 1 1/2" black pvc pipe from the gray water tank.
Not sure where its coming from yet, could be the pipe or a joint?
If I can find where the leak is coming from is there a product that will seal the pvc pipe?
Thanks, Mike
agesilaus
North Florida
Posted: 01/24/21 06:35pm Link  |  Quote  |  Print  |  Notify Moderator
Some of that self stick silicone repair tape will do a temp repair:
Repair tapes
You need to stretch the tape and pull it as tight as you can to get it to work.
Your local hardware will carry one or the other. You need to do a permanent repair sooner of later.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Monterey, California
Posted: 01/24/21 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Definitely sooner...not later. Leaks don’t improve and a black leak is nasty.
cavie
Posted: 01/24/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
flex tape as a temporary fix.
Dutch_12078
Winters south, summers north
Posted: 01/24/21 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
If I don't have repair tape handy for a low pressure leak, I've also had good luck using Eternabond on dry pipe. If the area is exposed to weather or road hazards, a couple of layers of Gorilla tape or similar over the Eternabond will provide protection. If it's a coupling or worn spot that's leaking, a Fernco rubber coupling can be used as a permanent fix.
Fernco 1-1/2"x1-1/2" Flexible Coupling
Dutch
2001 GBM Landau 34' Class A
time2roll
Posted: 01/24/21 07:08pm Link  |  Quote  |  Print  |  Notify Moderator
For black ABS "Plasti-Mend" will provide a permanent fix in all positions.
Buy direct from website or amazon.
675w Solar pictures back up
Posted: 01/24/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Dutch has an excellent idea.
BobsYourUncle
Calgary Alberta Canada
Posted: 01/24/21 08:29pm Link  |  Quote  |  Print  |  Notify Moderator
FWIW, I had a grey tank drip a couple of TTs ago.
Then one day I bonked the dump pipe on some dirt and grass in an awkward back up parking job. Leaked worse after that.
I took it apart to fix it and the black ABS pipe was only thrust into the fitting. The boneheads at the factory neglected to glue the pipe in place.
Easy fix, pull it apart, clean up the area, some ABS glue, done!
If it happened to me, it can happen to anyone.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
dpglifestyle
michigan
Posted: 01/25/21 03:42am Link  |  Quote  |  Print  |  Notify Moderator
I used JB Water weld to fix a cracked fitting on black tank. this stuff is made to fix water leaks and will even work under water
2015 Lifestyle LS36FW
2016 GMC 3500 CC Dually
Dave H M
IL
Posted: 01/25/21 05:05am Link  |  Quote  |  Print  |  Notify Moderator
Where is the drip located, out the end of the dump or somewhere along the pipe?
 > Drip
