RV.Net Open Roads Forum: Tech Issues: Drip
 > Drip
Bill.Satellite
Full-timer
Posted: 01/25/21 05:21am Link  |  Quote  |  Print  |  Notify Moderator
Keep in mind that if you don't know where the leak is, it may not be the pipe at all. It well could be another line leaking and dripping onto the pipe or running down some surface and running down the pipe. Be sure to look deep into the source before you worry about the cure.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
klutchdust
Orange, California
Posted: 01/25/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
Flex seal, if you have any left over you can make a boat out of a screen door. I have used this to seal a outdoor water fountain and after a few months it failed. Started out nice but.....
As Bill mentioned you need to see where it is leaking from. Liquids travel and then drop when they run out of something to follow.
jdc1
Rescue, Ca
Posted: 01/25/21 09:52am Link  |  Quote  |  Print  |  Notify Moderator
Since waste pipe is not under pressure, there are tapes meant just for your application at HD and Lowes. About $10/roll.
valhalla360
No paticular place.
Posted: 01/25/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
If it's on the PVC pipes or fitting, fairly simple.
Repaired a crack on a prior trailer with some epoxy and automotive fiberglass wrapped around it. I saw the trailer last summer and the fix is still there and sealing it 12yrs later.
If the tank gets a crack, that's a bigger challenge. There is special glue to seal it...anything else won't stick. Even with the special ABS plastic welding glue, I never did get it to stay sealed.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
time2roll
Posted: 01/25/21 10:54am Link  |  Quote  |  Print  |  Notify Moderator
I had a thin spot in a bottom corner of my ABS holding tank. It became a flex point as the tank would fill and was leaking. I used Plasti-Mend and some thin sheet ABS to seal and reinforce the area. I think it is now going on eight+ years with no issue.
Initially tried JB Weld and some tank epoxy. Both failed. I believe they failed because of the continued flexing.
675w Solar pictures back up
ksg5000
Oregon
Posted: 01/25/21 01:13pm Link  |  Quote  |  Print  |  Notify Moderator
Can't fix it until you locate where the leak is coming from.
Kevin
Mike P.
Des Moines, Iowa
Posted: 01/25/21 01:18pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the suggestions so far.
RV has been sitting for a while, and I just purchased it a couple days before seeing the drip.
Its cold and rainy here in AZ for a few days and I will crawl around under it soon and try to find the source of the drip.
Hopefully its an easy fix.
Mike
learntorv
Fulltimer
Posted: 01/25/21 01:36pm Link  |  Quote  |  Print  |  Notify Moderator
You may know this, but since it's been cold- mind the working temperature of whatever solution you come up with. Sometimes you'll have to wait for things to warm up before you can use different products.
Elk_traveler
maryland
Posted: 01/26/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
I have a small drip coming from the 1 1/2" black pvc pipe from the gray water tank.
Not sure where its coming from yet, could be the pipe or a joint?
If I can find where the leak is coming from is there a product that will seal the pvc pipe?
Thanks, Mike
Flex seal paste. It is a miracle worker for leaks. Had a leak a year ago and I put the stuff on thinking I would go back later and make a permanent fix but never did it works so well. The paste gives you the ability to put it on as thick as you like. Most TV advertise products are junk but this product does what Phil Swift says it will.
 > Drip
