RV.Net Open Roads Forum: Class A Motorhomes: Replace TV
 > Replace TV
DC&MC
formerly of Keizer Oregon USA
Posted: 01/26/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
We had already replaced the original TV years ago but now want to get a smart TV and get it a little bit bigger. As wide as what will fit between the side cabinets. Anyway I saw a picture of an install someone did that allowed the TV to be swung out for easy access behind. Any suggestions or pictures?
2006 Mandalay 40E motorcoach
2011 Ram PU
2012 Victory Cross Country mtc
From wherever we happen to be
wildtoad
Blythewood, SC
Posted: 01/26/21 09:56am Link  |  Quote  |  Print  |  Notify Moderator
They make tv mounts that allow the TV to extend out, swivel as needed. They make all kinds but here is one on Amazon.
TV Mount
Just a word about size... Make sure you measure the exact dimensions of the TV and space where you want it to fit and don’t assume all 32” TV’s (as an example) are the same physical size.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
Sandia Man
Rio Rancho, NM
Posted: 01/26/21 10:00am Link  |  Quote  |  Print  |  Notify Moderator
We did the same recently, wasn't overly complicated, sorry no pics to post. I have mounted our swing out hdtv brackets to a sturdy cabinet in the past, but with our Class A I mounted the tv bracket directly to the steel cage overhead. Solid as a rock, can be pivoted to virtually any viewing position, and readily swings out to easily access cabinets behind tv. Didn't use any specific tv bracket brand, just went to Amazon and ordered what was best suited to handle the weight/size, and provide full articulation.
Near DVNP, California
Posted: 01/26/21 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Swing out TVs are great but make sure they are strapped carefully when traveling.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Oasisbob
Portland Oregon 97266
Posted: 01/26/21 11:18am Link  |  Quote  |  Print  |  Notify Moderator
I have a swing out mounted 19 LCD TV. Your mounting point needs to be really solid. I bungee my TV when traveling. Also bigger TV means more power consumption if you boondock and more weight on the mount.
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
oldave
Tx
Posted: 01/26/21 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
I had some nice 5/8 plywood and made a door to mount my TV on.
The door is hung with a piano hinge from the top and a folding cabinet
door prop to hold it up when accessing the cabinet
https://www.ebay.com/i/265000907285?chn=........msclkid=2e273f841e8e1935a6095f946e2072f4
olfarmer
Iowa
Posted: 01/28/21 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
I replaced our built in front mounted TV with a larger flat screen on the swing out mounts. I really like it but I do strap it in tight when traveling.
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
jeromep
Eastern Washington State
Posted: 01/28/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
You'll want to find locking, articulated mounts. These are often designed specifically for RV use. You'll be able to identify these because they usually have some kind of pull chain that releases the articulating arm from a folded and locked position and when you fold up the mount and TV, you'll notice a distinctive click as the mount locks closed and holds the TV tight against the wall or space it is mounted. I've seen numerous ones on Amazon, but also at RV parts dealers and even CW.
jeromep
Posted: 01/28/21 10:46pm Link  |  Quote  |  Print  |  Notify Moderator
This is the type of mount I was thinking of for a bedroom application I'm looking to retofit a new flat screen in place of the old tube tv that is back there.
Locking TV mount
olfarmer
Iowa
Posted: 01/29/21 07:39pm Link  |  Quote  |  Print  |  Notify Moderator
WOW, that looks great, I wish I had known about it when I did ours!
 > Replace TV
