RV.Net Open Roads Forum: Class A Motorhomes: Replace TV
 > Replace TV
rgatijnet1
Posted: 01/30/21 09:30am Link  |  Quote  |  Print  |  Notify Moderator
Just be sure that you can hear the TV when it is mounted, especially if the TV speakers are open to the back, and you mount the TV in a cabinet with only the face visible.
jeromep
Eastern Washington State
Posted: 01/30/21 10:31am Link  |  Quote  |  Print  |  Notify Moderator
That is good advice. Most flat screens have rear mounted or down firing speakers. Some fire "through" the screen, some fire down and forward, usually at the bottom edge of the screen. One thing I've noticed is that flat screens retrofitted into old tube TV installations in older RVs do have a bit of an audio problem due to how the speakers work in these new TVs. It is almost as if we have to surface mount the new TVs to really get great audio performance. My rig is older and the previous owner did a really nice job of mounting a flat screen in the front TV enclosure, even tried to accommodate the audio issue presented by putting the TV in the enclosure, but it still requires the volume to be way up to enjoy the audio, and it still sounds tinny. On the other hand I'm working on replacing the tube tv in the back bedroom and have already determined that I'll "plug" up the hole that the current TV sits in with a finished wood panel, and then mount the bracket to that panel, and the new TV will be surface mounted to that bracket. I'll put a hidden hole and grommet in the panel and all the wiring will go back to the original outelts (12v and 120v) and coax port.
 > Replace TV
