RV.Net Open Roads Forum: Truck Campers: SiO2 Batteries
 > SiO2 Batteries
Geewizard
WA
Posted: 01/26/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
I'd like to hear from people who use the SiO2 batteries.
Are you happy with them?
Charging methods?
What kind of current loads do you have?
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
200W solar, MPPT controller, LED lights
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
jaycocreek
Idaho
Posted: 01/26/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
Do a search..BFL13 has a SIO2 battery or batteries and has run it through the test on the tech forum..Very impressive IMHO..
Williams AZ area
Posted: 01/26/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
Price is my only concern. Hopefully soon.
FWC
The Wilderness
Posted: 01/26/21 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
What is your intended use?
BFL13
Victoria, BC
Posted: 01/26/21 06:01pm Link  |  Quote  |  Print  |  Notify Moderator
Exactly the right question, FWC.
You can wade through the 12 page thread from last fall and get all confused maybe, or specify here why you are looking at these instead of regular AGMs, or whatever you would get instead. The SiO2 is very good, but you might not really need one, and they cost extra.
I got mine for the high draw ability on one battery to run a MW. Had a space and arrangement problem in the TC for getting the inverter and battery close enough together. Would not apply to all TCs. Does that high draw down to 20% SOC and voltage held up so inverter did not alarm off.
Day running to dog training place, did not need more AH. Did need MW for lunch and supper then go home. However, 100AH is not enough to go camping with. So then (of course [emoticon] ) DW wanted to go camping with the TC instead of the Class C. Drat! So now have two in the TC for 200AH. Was not the plan!
With one 100AH, charging limit is 27-30 amps so I used the Vector 35/20/10/2 charger set to 20 amps to charge it. Now with two, I can use the 55 amp converter.
Yes, happy with the SiO2 doing what it is supposed to do. I would not swap the four 6s in the Class C to use SiO2 or LFP though, since the four FLA 6s are doing the job just fine.
You need a good reason to spend a lot more for batts than usual, so FWC asks the right question.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
pianotuna
Regina, SK, Canada
Posted: 01/26/21 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Charging methods?
The owner of sanidump uses them and is happy.
https://www.sanidumps.com/product-testing-rv-batteries.php
Regards, Don
Geewizard
WA
Posted: 01/27/21 06:07am Link  |  Quote  |  Print  |  Notify Moderator
Boondocking. I have 220W of solar with a MPPT charger. No AC appliances. I have two 100AH deep-cycle AGM batteries now.
I am attracted by the LiFePo4 batteries for their reducted weight and current capability but not their need for a special charger. The SiO2 evidently can use a standard charger.
* This post was last edited 01/27/21 06:38am by Geewizard *   View edit history
Geewizard
WA
Posted: 01/27/21 06:18am Link  |  Quote  |  Print  |  Notify Moderator
Charging methods?
Good review, thanks.
phemens
Montreal, Canada
Posted: 01/27/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
I am attracted by the LiFePo4 batteries for their reducted weight and current capability but not their need for a special charger. The SiO2 eeidently can use a standard charger.
If your charger is programmable, the settings for LiFePo4 are not complicated. I'm a little puzzled though - if you're going to invest significant $ in batteries, a small investment in a new charger (if needed) is a problem?
2012 Dutchman Denali 324LBS behind a 2006 Ford F-250 V10 out of Montreal
1 DW, 1 DD, 1 DS, 2 HD (Hyper Dogs)
1200w solar, 600AH LIFePO4, Yamaha EF2000 gen, Samlex 3000w Inverter
Geewizard
WA
Posted: 01/27/21 06:37am Link  |  Quote  |  Print  |  Notify Moderator
No, the cost of a charger is not an issue.
I'm just investigating different battery types. I was unaware of the SiO2 batteries.
I'll likely go with LiFePO4 batteries because of their reduced weight compared to others.
 > SiO2 Batteries
