RV.Net Open Roads Forum: Class C Motorhomes: 10" hitch riser
 > 10" hitch riser
garmp
St Louis, MO
Posted: 01/26/21 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Class B+ and have recently purchased 2 ebikes along with a Kuat bike carrier. The carrier is made for ebikes & RVs. I think I need a 10" hitch riser to give visibility to my taillights & licenses plate. Is that an excessive rise for stability sake? I do plan on using a hitch stabilizer on the riser.
The carrier is rated for quite a bit more weight than the 2 bikes weigh, so I'm OK from that stand point.
If a riser of that height won't work, I'll have to devise something for the taillights & plate to be visible.
thanks
Our 2351D Phoenix Cruiser, Jack, has turned us from campers into RVers and loving it!
Seattle Steve
Tucson
Posted: 01/26/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
A 10" riser might work. but I would worry about it amplifying the vibrations.
I went with a 1-Up-USA rack for my ebike which works great. One of the reasons I went with it over the Kuat (other than I thought it was far superior) was the ability to add a lighted license plate holder. Look under accessories to see what it looks like. Perhaps you can engineer something similar for your rack.
CA Traveler
The Western States
Posted: 01/26/21 04:07pm Link  |  Quote  |  Print  |  Notify Moderator
Stability should not be a problem given the limited weight. See if you can borrow a riser and try it. It will move the carrier and bikes back about 6-8". Will there be any issue with license plate visibility?
I'd probably add LED lights to the carrier.
2014 Grand Cherokee Overland
Bob
Bumpyroad
Virginia
Posted: 01/26/21 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
years back I bought a riser of about that height to use on a roof top boat carrier and there was a warning that as I remember could only be used to lower, not raise, something that much. just add tail lights to the carrier you have.
bumpy
ron.dittmer
North-East Illinois
Posted: 01/26/21 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Hi garmp,
I would try the 10" riser and see how it goes. It seems like you'd be okay since you are not using the riser to tow a trailer.
You mentioned using one hitch stabilizer. I would use one on each of the two connections to minimize or eliminate the thrashing of your E-bikes.
Ron
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
CA Traveler
The Western States
Posted: 01/26/21 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
ron.dittmer wrote:
You mentioned using one hitch stabilizer. I would use one on each of the two connections to minimize or eliminate the thrashing of your E-bikes. Ron
X2 I use 2.
IAMICHABOD
Sunny So Cal
Posted: 01/26/21 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
As for the bouncing that others have talked about to make it less pronounced You need a good anti rattle device so you don't get so much play in the receiver,thus magnifying the movement and doing any damage to the bike rack and Bikes
I have tried almost every Anti Rattle device on the market, most have been no good or so complicated and cumbersome that they are useless. Including the Roadmaster type, or blue ox totally useless.
Until I found the one at Hitch Rider.
Their Hitch Vice is the best and easiest one I have come across and it really works.
Former El Monte RV Rental
Buying A Rental Class C
Beverley&Ken
Tottenham,Ontario
Posted: 01/26/21 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
What I have done to stabilize the bikes is just adding a couple of ratchet tie down straps. On my Carrier, the bike wheels sat in a carrier and I put the straps around the wheel and mounting cradle, the other end to the bumper bracket on the MH. On on each end of the bike and snugged down. Three point tie down made the bikes quite stable.
You don't need premium quality tie downs, think Harbor Freight (Princess Auto in Canada) or Walmart etc.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
bobndot
Posted: 01/26/21 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
Did you try the bikes on the rack of the rv yet ? Are you sure the taillights are blocked ? They usually shine thru the spokes.
ron.dittmer
North-East Illinois
Posted: 01/27/21 07:55am Link  |  Quote  |  Print  |  Notify Moderator
That surely looks to be very easy to install. I like that!
I was surprised to read that you felt the Roadmaster Quiet Hitch was not effective. I use a riser with a Quiet Hitch at each connection as shown below. Once they are on, there is "zero play" in the system.
I like your recommendation specifically for the quick on/off feature. I leave mine attached all trip long which helps make the Quiet Hitch work.
 > 10" hitch riser
