RV.Net Open Roads Forum: Tech Issues: installing a cutoff switch
 > installing a cutoff switch
Bigdog
silverdale wa.
Posted: 01/26/21 04:40pm Link  |  Quote  |  Print  |  Notify Moderator
I just had to replace the 12V distribution panel on my '01 Tradewinds DP and now have discovered that I have a major battery drain which seems to be before the cutoff switch and really don't want to get the mobile tech out again. I am thinking about getting a regular marine cutoff switch and installing that to totally cut off the power. I am not worried about the alarm as I already had to disconnect that. There are two ways to connect these, one is to cut the cable and install connectors on each of the cut ends and the other is to get a post connector and not have to worry about cutting that big piece of copper cable and pressing new ends on it.
So I'm looking for advice on this from folks that have done this.
GO COUGARS
2001 Tradewinds 7390 LTC
330 Cat Turbo Freightliner Chassis
2011 Jeep Liberty(toad)
'88 Mustang 5 Spd 5.0L GT convertible (not Toad)
CA Traveler
The Western States
Posted: 01/26/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
Here's my shunt and battery disconnect switch. Disconnecting alarms while using the RV would be unwise.
2014 Grand Cherokee Overland
Bob
Boon Docker
Posted: 01/26/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Seon
Lake Camanche, CA
Posted: 01/26/21 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
I too put a cutoff switch to disconnect the batteries when the RV is stored in the barn.
enblethen
Moses Lake, WA
Posted: 01/26/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
I would be trying to trace the drain and fix the problem.
Marine disconnect should work very well.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Oasisbob
Portland Oregon 97266
Posted: 01/26/21 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
You have a power draw somewhere and need to find it. Could be a dangerous situation.
Oasis Bob
Wonderful wife 3 of 4 kids at home. 1 proudly serving in USAF
2018 Ford Explorer
2001 Bantam Trail Lite B-19
HAPPY TRAILS">
midnightsadie
ohio
Posted: 01/27/21 06:30am Link  |  Quote  |  Print  |  Notify Moderator
find the problem. start by puting a meter on the battery, then pull fuses one by one, till the meter drops.
