RV.Net Open Roads Forum: Towing: Replacement WDH shaft
Search only in Towing
Open Roads Forum  >  Towing
 > Replacement WDH shaft
cmarkj
Fulton, Il - on the mississippi river
Posted: 01/26/21 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
Gathering info in case I need it in a month or two. Just upgraded our TV to a 3/4 ton. Of course, that increased the receiver size to a 2 1/2” from a 2”. I think it may also be higher enough that I might need a different shaft because I may not be able to drop the ball enough on my existing one. Packed away right now so I can’t be sure, but I’d like the info in advance so if I need one, I can get it quickly.
Two questions: do I get a 2 1/2” if I can for my style of hitch and where do I get one?
I have a preo-series round bar with 1200/12000# set up.
Thanks
Always looking for the perfect site.
afidel
Cleveland
Posted: 01/26/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
You're looking for a shank, not shaft. Blue Ox makes a 2.5" drop shank that should work well for your application. BXW4028
CURT 17132 is an option, though it's so much cheaper I have to question the quality.
Reese 54977 is the other option I've seen, but it's only for pretty significant drops so not as flexible as the blue ox.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 long bed
Equalizer 10k WDH
APT
SE Michigan
Posted: 01/27/21 07:23am Link  |  Quote  |  Print  |  Notify Moderator
I have the Reese Strait Line WDH which came with the Reese 59740. IT worked well for my F-150. When I replaced the F-15o with the Suburban, I needed more drop like you and ordered the Reese 63971.
If you need to buy a new one, then I recommend a 2.5" square vs. 2" and sleeve. Some people have reported excessive wear and towing instability using the adapter. I have not found a Reese Titan PN for similar drop.
Etrailer and Amazon Prime ship very quickly. If you can plan an extra few days of the TT in your driveway in the spring, you should be good. Local towing shops and RV dealers will likely have parts in stock as well, but may be more expensive than online.
2017 Subaru Outback 3.6R
Boomerweps
Hills of PA
Posted: 01/27/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
Did you ever measure your previous and new TVs hitch heights?
With some, it’s significant but others minimal.
Moving from my 2008 Explorer to my 2019 F150, the difference was within an inch, within tolerances for me. After “flipping” the TT axle, I had to lift the WDH ball about 5”, which required actually flipping the WDH shank.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
mbopp
Henrietta, NY, USA
Posted: 01/27/21 09:08am Link  |  Quote  |  Print  |  Notify Moderator
My F250 sits about 4" higher than my F150. I had enough drop to re-use the shank with a 2-1/2" to 2" Reese adapter.
2017 Grand Design Imagine 2650RK
2019 F250 XLT Supercab
Just DW & me......
Posted: 01/27/21 09:10am Link  |  Quote  |  Print  |  Notify Moderator
??? Strange statement
2017 Heartland Torque T29
Posted: 01/27/21 09:13am Link  |  Quote  |  Print  |  Notify Moderator
This is a poor permanent solution. Hitch adapters induce bending stress on the hitch pins (and bend them) and wear out the hitch pin holes in the receiver.
Unless you're only doing occasional light duty work with the adapter, get the right size hitch shank.
BTDT, cut more than one bent pin out of a receiver and ended up with wallered out pin holes on the receiver.
afidel
Cleveland
Posted: 01/28/21 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Really, when the other two options on the market are within 10% of each other and the third is 30% cheaper than the less expensive option it's generally that way for a reason. Markets are generally fairly efficient so there's no way to save 30% and present a good of the same quality.
As but one example when I bough the AC for my house I got 5 quotes, they varied in price from $2k to $8k, the $2k quote was a contractor grade brand installed by unlicensed day laborers, there were 3 quotes in the middle within $500 of each other all using similar grade equipment and licensed and insured professionals, and the $8k quote was for a Cadillac system with stupid high labor rates. I threw out the high and low bids and selected from the middle 3 based on reputation. They ended up having to come back to do some rework and didn't charge for the trip or the materials to make it right. The unit lasted 17 years, almost four times the warranty period.
You're free to spend your money as you wish but life has taught me there's no free lunch and deals that appear to be too good to be true almost always are.
CharlesinGA
South of Atlanta, Georgia
Posted: 02/08/21 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Since its not really cheaper, I am not sure where this comes from. I looked up the Curt (11 holes), a similar but slightly shorter Blue Ox (9 holes), and an Equalizer (not sure on the holes, the pics do not reflect the actual item) and they are $222, $222, $239 respectively. The Equalizer is welded up, and I suspect may be taller (more holes) but does not list a weight rating. The Blue Ox and the Curt are both cast steel and the Curt is rated at 15K lbs and the Blue Ox is rated at 20K lbs, possibly due to not being as tall.
So no, the price does not vary wildly between brands and the Curt is in the same price range as the others. Some people may not like the cast steel but if properly manufactured, it is as strong as a welded up one.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
BarneyS
S.E. Lower Michigan
Posted: 02/09/21 09:11am Link  |  Quote  |  Print  |  Notify Moderator
Nothing wrong with the Curt. They have been around for years. I had a Curt shank on my truck. It was a solid, welded piece and didn't wobble or shake at all. I never had a single problem with it.
Barney
Not towing now.
