RV.Net Open Roads Forum: Tow Vehicles: Am I overloaded?
Search only in Tow Vehicles
 > Am I overloaded?
shades9323
Lansing, MI
Posted: 01/28/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
My best advice if not already done throw on a set of "E" tires.
E’s have been on the truck from day 1.[emoticon]
shades9323
Lansing, MI
Posted: 01/28/21 04:00pm Link  |  Quote  |  Print  |  Notify Moderator
BurbMan wrote:
You're fully loaded for sure, but as long as you are under on the axle rating and it tows good, I wouldn't be too concerned about it. Even adding another 100# shouldn't be a big deal.
I wouldn't mess around with a 150 with the max payload package...if you need/want more capacity go to a 250/2500.
Still have to drive it to work everyday and my current truck barely fits in the parking ramp at work!
shades9323
Lansing, MI
Posted: 01/28/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
I agree he's a little over but if it's towing well, probably not a big deal.
I disagree with the OP needing to go to a 3/4 ton if he wants to upgrade the truck. He has an absolutely pitiful payload with the current truck. He gets away with it because he's towing a small 4500lb (loaded) trailer and presumably isn't carrying much in the truck bed.
There are plenty of 1/2 ton trucks with payloads upwards of 1600-2000lb that could be well suited to trailers in the 6-7,000lb (loaded) range.
If he's looking at much above 8,000lb (and certainly by 10,000lb), then a 3/4 ton starts to be desirable option.
Not much in the bed at all. There is about 200 lbs of bikes and bike rack sitting above the bed though.??
bguy
The Rock
Posted: 01/28/21 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
Giver.
I'm pretty sure I'm farther over than that. Not that it makes it OK for you but in my experience you will be fine.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
Cummins12V98
on the road
Posted: 01/28/21 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
Smart man!!! Many don't understand the fact TT's are prone to swaying and any little movement can compound that. Firm tires are so important.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
time2roll
Posted: 01/28/21 05:09pm Link  |  Quote  |  Print  |  Notify Moderator
As long as it feels safe I would wait until you trade up on the RV to look at new trucks.
Of course if money is easy by all means get a bigger truck.
675w Solar pictures back up
 > Am I overloaded?
