RV.Net Open Roads Forum: Technology Corner: Directv
 > Directv
CA Traveler
The Western States
Posted: 01/28/21 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Carl n Susan wrote:
I believe DNS is still available for RV Accounts (not household). You can only get one set (NY or LA) and it will be the ones closest to your billing address.
I have read that an LA or NY billing address gets them across the country, but others have written that is not true; the spot beam is LA is different from the country wide (CONUS?) signal. Beats me, and I have no way to verify.
Good to know about DNS.
When I changed the service address for LA locals I got the LA locals and the LA DNS stations (channels 3xx) which are not on a spot beam and available for the 49 states.
2014 Grand Cherokee Overland
Bob
2chiefsRus
USA Somewhere
Posted: 01/28/21 12:41pm Link  |  Quote  |  Print  |  Notify Moderator
original poster here - I called a couple different times today, something I used to do trying to find someone at AT&T who actually knows what they are talking about, still getting conflicting information from them. I think I will go back to my original plan and spend the money to convert the Traveler to Dish this spring before heading out. AT&T just don't seem to want my business.
Dave & Kathy
2007 Monaco Knight 40PDQ towing 2018 Ford F-150 & 2017 Harley Trike
Fulltime 2007 to 2016, now halftimers
Before you give someone a piece of your mind, make sure you can get by with what will be left.
Our Blog
National Parks Visited
2chiefsRus
USA Somewhere
Posted: 01/28/21 12:43pm Link  |  Quote  |  Print  |  Notify Moderator
It may still be available but not if you can't find someone at Directv who knows how to sign you up or even give you a price for a service they have never heard of.
CA Traveler
The Western States
Posted: 01/28/21 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
Keep asking the computer for technical support until you get a human. Then have them change the service address to LA locals. It may be helpful to actually be in the LA area to confirm you have the locals. That will also give you the DNS channels. No additional charge. That's how I do it and I always get a technical support person first.
One time I used chat but it wasn't any faster.
JAC1982
Colorado
Posted: 01/28/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
We have DirecTV, with service at our home in Colorado. When we use our Winegard dish while traveling with DirecTV service, we still get the Denver local channels.
If you want the local channels I don't think DirecTV offers a service like that, at least not one that's a total PITA to deal with as you move around. From what I read, Dish is more RV friendly. We aren't switching because Dish doesn't have our local sports station, and also we don't travel enough for it to be a big deal to not have local to our location stations.
2020 Keystone Montana High Country 294RL
2017 Ford F350 DRW King Ranch
2021 Ford F350 SRW Lariat Tremor
RAS43
Littleton,CO
Posted: 01/28/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
You probably are still traveling within the Denver spot beam. I also have Direct and loose the Denver stations in upper Montana, southern New Mexico and eastern Nebraska. It is apparently a large spot beam. I have switched service areas at times but it is a pita due to inexperienced reps.
missnmountains
Southwest Florida
Posted: 01/29/21 06:03am Link  |  Quote  |  Print  |  Notify Moderator
When we lived in Colorado, we would get them up to Glendoe, WY and down near 4 corners. It was a very large spot beam. Once north of Glendoe, we would lose them. Down in Arizona we would lose them.
Ken
2016 Newmar Dutch Star 4369
Our Blog: Lawrence Adventures
Belgique
Hickory, NC
Posted: 01/29/21 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I get DNS for NY and LA.
Hickory, NC
2007 Fleetwood Discovery 40X
Bill.Satellite
Full-timer
Posted: 01/29/21 08:50am Link  |  Quote  |  Print  |  Notify Moderator
The accurate info is here. You CANNOT get local FL channels once you get too far away from your home stations. There are things called spot beams that broadcast the signal. Imagine a flashlight shining on the Earth and only covering a few hundred miles. Once you drive outside the flashlight beam you are "in the dark" and will lose ALL Network programming. Things like Food Network and TBS are NOT using a spot beam but rather a CONUS beam (CONtinential US) and are available where ever you travel in the US, some of Canada and some of Mexico. Even AK but SD only and it takes a bit of magic with a Trav'ler.
Yes, DNS is still available but you can receive only East or West. This is determined by where the RV is registered. If you are in ET or CT time zones you will get East MT or PT time zones get the West feed.
DISH is not a bad plan but their signals are spot beamed as well so leaving FL using DISH will cause the same loss of signal but it is much easier to change your location with DISH than it is with DTV.
I have been fulltime with DTV since 2000 and have both E & W so I'm pretty spoiled by the Grandfathered DTV service I have.
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
rklyon
Posted: 04/24/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
We are full timing and had a few hiccups until we figured out the right people to talk to. You have to call and ask for the movers Department. There slang for it is "Snoowbird Service". Ask them to change your location only and not your billing address. The direct number to that department is 877-407-4720. Ignore all of the choices and speak to a human.
 > Directv
