RV.Net Open Roads Forum: SRW 3500 Dodge work with a Arctic Fox 811
 > SRW 3500 Dodge work with a Arctic Fox 811
bwlyon
64633
Posted: 01/29/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I have a similar set up. S85RS Ascent camper on our 2015, 6.4 gasser Megacab 3500 SRW. Just like the Arctic Fox 811, the ascent is a SB camper with a slide, and it is heavy just shy of 5K fully wet and ready to camp. Now the 811 is a few hundred pounds lighter though, but only a few hundred fully wet and ready to go. You are going to be over every where with the exception of the steer axle. The 811 like my camper really needs to be under a dually. Like you we get by with the SRW, but our next truck will be a dually. Our weight fully loaded and ready to go is as follows. 13000lbs GRoss weight. With 8700lbs on the rear axle. That’s 1600lbs over GVWR, 1700lbs over rear axle capacity, 1300lbs over tire weight rating for the pair of rear tires.
billtex
RI
Posted: 01/29/21 05:54pm Link  |  Quote  |  Print  |  Notify Moderator
Go with a gasser and gain 600# payload.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
Posted: 01/30/21 07:04am Link  |  Quote  |  Print  |  Notify Moderator
And 0# on the rear axle where all the load will be.
2017 Heartland Torque T29
specta
utah
Posted: 01/30/21 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Regular cab, 6.4L Hemi, 2-wd 5170 payload.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
Bedlam
PNW
Posted: 01/30/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
You can haul the AF811 on a SRW, but you most likely will be over GVWR while still within axle ratings. This may require aftermarket upgrades of wheels and suspension to get safety and stability so you need to decide if you start with a DRW or modify a SRW with additional cost.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE-VW TransBuggy 1200
ticki2
NH
Posted: 01/30/21 11:41am Link  |  Quote  |  Print  |  Notify Moderator
Is that for a drw ? There was no configuration for a 3500 srw that went that high on the Ram site .
'68 Avion C-11
'02 GMC DRW D/A flatbed
specta
utah
Posted: 01/30/21 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
I have no idea if it is or not.
Kayteg1
California > Nevada
Posted: 01/30/21 01:39pm Link  |  Quote  |  Print  |  Notify Moderator
+ low traction on front wheels when you get TC with COG behind rear axle.
JIMNLIN
Oklahoma
Posted: 01/30/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
Just like driving a srw with that camper on it is “no big deal.”
You guys do realize the OP has already been hauling the camper on a srw truck, right?
Guessing if he had issue with it, his thread would be about a dually.
The OP says..... "my 05 has had a lot of upgrades to handle the 811 and pull my 18' aluminum boat."
Most folks would assume he has upgraded wheels/tires and rear spring pack help for carrying the 811 as the '05 3500 SRW can have a 6200/6500 RAWR.
Granted it may have 18" or 20" OEM tires and wheels but the older trucks were a bit short on rear spring pack capacity vs the newer gen SRW rear spring pack.
srschang
Western NY
Posted: 01/31/21 08:25am Link  |  Quote  |  Print  |  Notify Moderator
This is a common misconception. Here's the data from Ram. The RAWR is the same diesel to gas, the FAWR is higher on the diesel, and the GVWR and Payload are higher on the diesel.
2020 Ram 3500 SRW Crewcab Longbed Cummins, 2019 Northstar 12 STC
