RV.Net Open Roads Forum: SRW 3500 Dodge work with a Arctic Fox 811
 > SRW 3500 Dodge work with a Arctic Fox 811
billtex
RI
Posted: 01/31/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
srschang wrote:
billtex wrote:
Go with a gasser and gain 600# payload.
This is a common misconception. Here's the data from Ram. The RAWR is the same diesel to gas, the FAWR is higher on the diesel, and the GVWR and Payload are higher on the diesel.
Don’t know much about ram, do they have that data showing same tranny in gas and diesel? Apples2apples would be netter comparison.
It’s it interesting as the base weight of gasser is so much lower. Where does the available payload go? Typo?
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
srschang
Western NY
Posted: 01/31/21 10:44am Link  |  Quote  |  Print  |  Notify Moderator
I assume they beef up the front suspension (springs, shocks, etc) to accomodate the heavier diesel. Maybe they overcompensate a bit and that results in the higher payload and FAWR of the diesel?
2020 Ram 3500 SRW Crewcab Longbed Cummins, 2019 Northstar 12 STC
billtex
RI
Posted: 01/31/21 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
Hard to read the chart but it looks like 800# delta. Which is just about the weight of a diesel vs gas engine.
Still don’t understand where all that payload goes?
Maybe Ram uses some pixie dust?
rhagfo
Portland, OR
Posted: 01/31/21 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
bwlyon wrote:
I have a similar set up. S85RS Ascent camper on our 2015, 6.4 gasser Megacab 3500 SRW. Just like the Arctic Fox 811, the ascent is a SB camper with a slide, and it is heavy just shy of 5K fully wet and ready to camp. Now the 811 is a few hundred pounds lighter though, but only a few hundred fully wet and ready to go. You are going to be over every where with the exception of the steer axle. The 811 like my camper really needs to be under a dually. Like you we get by with the SRW, but our next truck will be a dually. Our weight fully loaded and ready to go is as follows. 13000lbs GRoss weight. With 8700lbs on the rear axle. That’s 1600lbs over GVWR, 1700lbs over rear axle capacity, 1300lbs over tire weight rating for the pair of rear tires.
I sure don’t want to be on a road anywhere near you when moving! You are a rolling lawsuit!
ADA6969
SPARKS,NV
Posted: 02/01/21 07:50am Link  |  Quote  |  Print  |  Notify Moderator
I Bought a 2002 990 A/F from 2 lady's it was on a 2003 Ram 2500 extra cab long bed. had air bags and Michelins. They Bought the truck and camper At same time never took camper off the truck. the truck had 102,000 miles on it.
2012 RAM 3500DRW MAX TOW 4WD AUTO STD CAB ST DIESEL STABLE LOADS AIR BAGS AND RS9000XLS, ROADMASTER 1 3/8" REAR SWAY BAR 2021 AF 1150 DRY BATH TOWING 2017 JEEP RUBICON JKU BUILT. OR 2020 JEEP RUBICON JL BUILT
Geo*Boy
Unknown
Posted: 02/01/21 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
If they didn’t know the difference between the way a properly set up rig handled and the one they had handled, they just went with it.
ADA6969
SPARKS,NV
Posted: 02/02/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
O I see. So you are saying it handled bad. I drove it after I bought it to swap on to my truck it was fine buy the way was a 96 dodge 4wd 3/4 ton 360 V-8
Posted: 02/03/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
And everyone’s opinion is different. I’m with you, no problem hauling heavy for the most part. Hauled a AF 860 on a Dodge 2500 for years.
Some folks aren’t comfortable with anything less than race car handling and can’t sleep at night if their Cat scale ticket isn’t lower than their door sticker. And some would put my camper on a F150.
And most of us are somewhere in the middle, either through knowledge and experience or ignorant bliss!
TxGearhead
Posted: 02/03/21 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
My story...I had a 2016 Ram CC LB 4X4 Cummins SRW. I bought the Bigfoot and installed a Big Wig. Driving back to Houston from Maryland wasn't too bad. But when I loaded it up for an extended winter trip it wallowed and tilted. I stopped at a scale and I was way over payload (4100#) and up against GVW and tires. I dumped a full load of water at the scale. When I got back home I ordered the 2018 dually. I transferred the Big Wig to the dually. The difference was like a 1977 Olds Delta 88 and a 2021 Corvette.
I would order a 6.4 gasser DRW with the Aisin if they offer it. Also definitely the optional 55 gallon gas tank . Maybe the self leveling air suspension too. Put a Big Wig on it and call it good.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
ADA6969
SPARKS,NV
Posted: 02/03/21 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
GRIT DOG. Amen You hit it right on the head.
