RV.Net Open Roads Forum: Class A Motorhomes: Need an Education
 > Need an Education
Page of 5
Executive
Posted: 01/30/21 11:33pm Link  |  Quote  |  Print  |  Notify Moderator
luvmydogs wrote:
snip/ Thank all of you who DID explain why you leave your rigs running. We had no idea jacks and slides needed the motors on, and learned alot more about the big rigs we also didnt know, so thank all of you FRIENDLY rv'ers who didnt tell me why I posted here at all. I got more of an education than I needed.Thank you
Perhaps, if you brewed a quick cup of coffee and visited the neighbor who left his rig running and was seated, you'd get more of an education of the foibles of diesel coaches. You might also meet a new 'friend'. Afterall, aren't we all proud of our rigs? I have no issue making new acquaintances at whatever campground we are at. Perhaps he was having an issue with his coach and could have used your assistance. Meeting people and being friendly is what rving is all about. Get out and start enjoying life and all it has to offer....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
GIB2
Welland
Posted: 01/31/21 10:57am Link  |  Quote  |  Print  |  Notify Moderator
I would like to share some thoughts. First older diesels rattle severely and of course also quite loud. They also spew black exhaust and smell badly. Newer diesels that haven't been tuned or DEF delete don't smoke ,smell and all three if stock are extremely quiet.
My new 2020 Duramax has a larger rad, larger fan and new improved oil cooler.
The manual states if you have been working hard to let the engine idle at least 10 Minutes. If you shut it down to early it will automatically start itself back up. As previously mentioned to hot of oil will take the bearings out of the turbo and the vanes rub the case and the debris goes through the engine. that results in $20,000 for an engine.
On behalf of the big diesel pushers the air pressure gauge only shows what is in the primary and secondary tanks. It is not fully charged that fast as it still has to fill brake chambers etc . Spring brakes start to come on at 60 psi .but they don't release at 60 psi. Many States have no manditory air brake endorsement so you have to bear with the procedure they go with.
luvmydogs
Ct
Posted: 01/31/21 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
Wow the big rigs certainly have more to know than 5th wheels or travel trailers. Thanks for the info. I keep looking at all them and are amazed how many there are. Other than the gorgeous paint jobs, the one word that always comes to mind in capital letters is BIG. To me they are just big. Which when in it would be wonderful but I am a panic pulling a small trailer, I think I'd be a mess on the road with one of those. I'm jealous of you all who can drive them so easily.
jeromep
Eastern Washington State
Posted: 02/01/21 01:19pm Link  |  Quote  |  Print  |  Notify Moderator
Depending on if you are driving a DP or a gasser (rear axle placement has an effect on handling), you get used to things like tail swing, turning radius, and having a "sense" of where your rear end is when backing up or in tight quarters. Cameras help a lot, and new rigs have lots of them. Older ones are lucky to have a rear camera. The folks driving the big ones do a lot of route planning. When you are that big you don't drive anywhere without a plan. And you gain a certain amount of realistic expectation in terms of the amount of ground you can cover in a day and where you can actually camp vs. where you would ideally like to camp.
Page of 5
 > Need an Education
