RV.Net Open Roads Forum: Class A Motorhomes: Need an Education
 > Need an Education
Page of 5
bgum
South Louisiana
Posted: 01/29/21 08:24am Link  |  Quote  |  Print  |  Notify Moderator
They don't know any better or don't care.
DarkSkySeeker
Freestone, California
Posted: 01/29/21 09:03am Link  |  Quote  |  Print  |  Notify Moderator
luvmydogs wrote:
Why do most of you feel the need to leave your vehicles running for long amounts of time before you pull out and long amounts of time when you pull into a campsite?
While I was pulling in and getting straight in the spot, a neighbor came over and said his wife wanted me to shut off my rig. I had not been there 10 minutes, and most of that was manuvering.
There is something special about camping in an RV.
luvmydogs
Ct
Posted: 01/29/21 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Okay, case to point. Sitting here reading all your posts a guy came in and the rv has been running for 15 minutes. He's out there sitting down. It's not a big enough battle, hence just ads to another reason why I'm done rv'ing, but certainly didn't make the decision. To one who asked why I care? Well I see nothing good about sitting next to or within hearing of all these rigs and having to listen to them for so long. If it wasnt a big deal, maybe you'd see more rv's sitting in truck stops.There are some campgrounds that honestly are mostly the big rigs, some not so much. But I have noticed over the years that consideration for your neighbors which are right there, is less and less. One thing if your the only one in the camping area or campground, but most of the time, YOU ARE NOT. Have a little consideration for the other campers, that's all I'm saying and honestly only posted this because I do not have a big rig and wanted to find out if this was nessesary. We figured it was not.Maybe some with think about it now, maybe not. lol
Executive
Posted: 01/29/21 10:27am Link  |  Quote  |  Print  |  Notify Moderator
I have a "procedure" I've followed for the past 13 years or so. I start the engine, set the idle up and while the coach is airing up, I disconnect the sewer and water. When I hear the governor kick off I go back inside, kick down the idle and turn off the coach. I then pull in the slides as per mfgs recommendations and complete my preflight checklist. I start her up again and pull out. Sometimes I will leave it idle while hooking up the toad which takes all of three minutes. If this procedure "offends" anyone...too bad. It's what works for me. Get earplugs.....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
FormerBoater
South Florida
Posted: 01/29/21 10:49am Link  |  Quote  |  Print  |  Notify Moderator
The best practice for deploying jacks, slides etc. for most DP's (Monaco's have a different procedure)is to have your engine running. Some rigs will not allow you to perform these functions unless the engine is running.
By the time you are level and your slide(s) are deployed you can turn the engine off as the turbo will have cooled sufficiently.
As far as campground depatures, DP's will need to be running to air the suspension, retract jacks and slides (except Monaco's). In very cold weather most of us have block heaters and can "pre-warm" the engine prior to starting and we know that a diesel engine idling is NOT warming up!
There is nothing wrong with shutting down the engine if you need more time to complete your "pre-flight" checklist.
So, there is no requirement for extended idling (my rig has a mechanical diesel but the engine manual calls for 5 minutes idling prior to shut-down, it will take me those 5 minutes to deploy the jacks, level and then deploy the slide so it has never been an issue).
However, hyper-sensitivity to the sound of diesel engines is not compatible to the RV lifestyle IMHO.
FWIW, have not witnessed excessive idling in our 12 years of owning the Eagle.
We camp mostly in the SE USA, primarily Florida.
Dave
1998 American Eagle 40EVS
down home
south
Posted: 01/29/21 12:00pm Link  |  Quote  |  Print  |  Notify Moderator
I always let the engine idle 3 to 5 minutes, per manual, Those turbos get real hot and their bearings and seals too! The expense to replace one at 125.00+ an hour 1senoughfr a new golf cart. Not going to risk it by not letting the turbo cool down for a bit.
ernie1
Sacramento,California,USA
Posted: 01/29/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
I think the different opinions stated here is a matter of whether you're on the giving or receiving end of things. Just because you're sitting in a campsite that is peaceful and relaxing you shouldn't be bothered by the guy that pulled in next to you spewing diesel smoke and fumes with the engine clattering away for up to 15minutes? For the record I have a diesel rig and am conscious of how others are affected by my presence.
ferndaleflyer
everywhere
Posted: 01/29/21 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
I can find more serious things to complain about. Noise, I take out my hearing aids! LOL
way2roll
Wilmington NC
Posted: 01/29/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I can't imagine people would leave their rigs idle for long periods of time for the fun of it. There has to be a valid reason, or they just don't feel like turning it off for a few minutes only to turn it back on again. Big deal. I think in the last 10 years I've seen someone idling an RV or truck more than 10 minutes about as many times as I can count on one hand. There's lot's of stuff to complain about while camping. Lots of folks are noisy and often into the night. Lots of folks don't know how to make a fire that doesn't smoke out half the campground. Lots of folks take forever at dump stations. It's a long list. None of these are malicious or intended to aggravate anyone. They are probably oblivious to it bothering anybody. When you have a lot of different people from all walks congregating in the same CG, you realize fast that most people don't do things they way you would. That doesn't make it wrong. They could very well feel the same about something you are doing. I am certain at some point you irritated someone with something you were doing and you had no idea. It's life. And you can choose what to let bother or not you and how to react to it.
time2roll
Posted: 01/29/21 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
I have had the early morning diesel idle treatment for full hour before they finally pulled out a 6:30am.
I also had a diesel pull in across the access road in Yosemite and after 15 minutes I was getting nauseated from the exhaust that we just left camp for a couple hours.
A few others but those are the worst I recall.
675w Solar pictures back up
Page of 5
 > Need an Education
