RV.Net Open Roads Forum: Fifth-Wheels: Bathroom heater vent not blowing
 > Bathroom heater vent not blowing
Ronaldlee
Concord, NC
Posted: 01/30/21 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Our Alpine 3720FB bathroom furnance vent not blowing air through it. No blockage as we can see. Vent is hot to touch. Anyone have any suggestions? Thanks.
12th Man Fan
Flower Mound , Texas
Posted: 01/30/21 10:10am Link  |  Quote  |  Print  |  Notify Moderator
I would suspect it has come loose or is kinked in the basement where it comes off of the distribution box. The bathroom is usually on a individual duct and if yours was built like mine was it probably needs some attention with some duct tape to close up all of the leaks.
Good luck
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
Old-Biscuit
Verde Valley
Posted: 01/30/21 10:12am Link  |  Quote  |  Print  |  Notify Moderator
New problem OR existing problem?
Vent is HOT....where?
AT the register or at the furnace discharge plenum connection?
If Duct is connected at furnace discharge plenum and register is hot then you have a collapsed/obstructed duct.
Cheap inspection camera own the register and/or in thru duct at furnace
US NAVY------USS Decatur DDG31
Ronaldlee
Concord, NC
Posted: 01/30/21 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the advise. Will try all of the suggestions. This is our first 5th Wheel. Have had motorhomes. This is our first total inspection after we bought and brought it home.
TXiceman
Full Time RVer
Posted: 01/30/21 05:30pm Link  |  Quote  |  Print  |  Notify Moderator
If the vent is hot, it is getting flow, otherwise it would not get warm. Lay a piece of toilet paper across the vent to see if it moves.
Ken
Amateur Radio Operator.
midnightsadie
ohio
Posted: 01/30/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
X2 you might be expecting more than it can give.
FLY 4 FUN
Alberta
Posted: 01/31/21 08:34pm Link  |  Quote  |  Print  |  Notify Moderator
Is the bathroom area visible from below in the 5er basement? If so you should be able to trace the paper thin dryer vent "slinky" that runs from the furnace to the floor vent. Following it from source to opening should show you if theres any reason its lacking flow.
2012 Dodge Ram 3500 crew SB 4x4 CTD 3.73
2015 Brookstone 315RL
2009 Colorado 29BHS (sold 2015)
05 Jayflight 29BHS (sold 2008)
99 Jayco Eagle 12SO (sold 2005)
