RV.Net Open Roads Forum: Towing: 2500HD ride
Search only in Towing
Open Roads Forum  >  Towing
 > 2500HD ride
Les Steward
Fort Worth, Tx
Posted: 01/30/21 02:56pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2012 2500 HD Cummins Diesel GMC and tow a 10,000 lb bumper pull. I have added two leaf springs on each side of truck. What can I do to improve the bumpy ride while towing the trailer?
rhagfo
Portland, OR
Posted: 01/30/21 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Well if you have a Cummins engine you have a Ram, if it is a GMC it should be a Duramax. Springs don’t fix bounce a good set of shocks should fix excessive bounce. Bilstein is a great towing shocks.
CA Traveler
The Western States
Posted: 01/30/21 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
9 year old shocks may need replacing. Koni is also a good shock.
2014 Grand Cherokee Overland
Bob
KD4UPL
Swoope, VA
Posted: 01/30/21 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
Why did you add leaf springs? A 10,000 pound trailer probably has a 1,200 to 1,500 pound tongue weight. That should be well withing the payload capacity of a 2500. Are you using a WDH? Is it adjusted right? I agree, put some good shocks on it, Bilstein or KYB Mono Max.
How much air are you running in your tires? If you have them inflated to 80 psi it is likely too much. Weigh the axles and consult a tire load inflation chart and inflate accordingly. I would be 65 or 70 psi would be about right.
edatlanta
Maplesville, AL Home Base
Posted: 01/31/21 05:51am Link  |  Quote  |  Print  |  Notify Moderator
I just replaced a set of shocks on my truck. Bilstein is the brand for me and has been since truck was new.
Ed
KM4STL
2006 GMC 2500HD CCSB 4x4 Duramax/Allison, Titan 52 gallon fuel tank, Prodigy Controller, B&W Companion Hitch, Progressive Industries EMS-PT50C, TST Systems 507 TPMS
2010 Jayco Designer 35RLTS,Cummins/Onan RV QG 5500 EVAP
Fulltime since 2010
nickthehunter
Southgate, MI
Posted: 01/31/21 06:29am Link  |  Quote  |  Print  |  Notify Moderator
Take the two springs you added off, buy a weight distribution hitch, install it and get it adjusted properly, and you’ll improve your ride by leaps and bounds.
valhalla360
No paticular place.
Posted: 01/31/21 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Stiffer springs make for a rougher ride unless the load increases proportionally. Since a 2500 should have no issues with the hitch weight of a 10k trailer, you made it more stiff.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Cummins12V98
on the road
Posted: 01/31/21 07:51am Link  |  Quote  |  Print  |  Notify Moderator
Get rid of the leaf springs, install Bilstein's on 4 corners and add air bags. Trick is to set with just enough air to have a level ride.
Also air your tires based on actual loaded weights. Use tire weight/inflation chart for your tires. add 5psi to rears and 10 to fronts to what the chart says.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
goducks10
There
Posted: 01/31/21 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Never had that issue with our 12 Cummings Powermax. Try KYB Monomax shocks. I put some on our 12 Dodge Ram and they worked great and are cheaper than Bilstiens.
Like others have said drop the springs and add or adjust the weight distribution hitch.
opnspaces
San Diego Ca
Posted: 01/31/21 09:56am Link  |  Quote  |  Print  |  Notify Moderator
Do you currently use a weight distribution hitch? If so I agree with the others to remove the added springs and spend some time adjusting the weight distribution hitch. I would look into adjustments before putting down any money on new anything.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
 > 2500HD ride
