RV.Net Open Roads Forum: Tech Issues: Alternators and Lithium Batteries
 > Alternators and Lithium Batteries
Son of Norway
Denver, Colorado
Posted: 01/30/21 10:26pm Link  |  Quote  |  Print  |  Notify Moderator
I like to boondock. I currently have 4 AGM batteries for a total of about 480 amp-hours, of course only about 200 useable. I would like to purchase some lithium batteries and put together a system of 400-500 amp-hours, about the same capacity.
One thing that is holding me back is what will happen that morning when I drive away from camp with depleted batteries and all the charging load goes on my alternator. It is a Lestek dual-output rated at about 130 amps. It puts out a constant voltage around 14.1 volts.
I've seen videos of fried alternators. Can my alternator handle that load, or would I need to add some kind of temperature and voltage regulated system and/or a regulated DC-DC charger?
Thanks for your wisdom.
* This post was last edited 01/30/21 10:40pm by Son of Norway *   View edit history
Miles and Darcey
1989 Holiday Rambler Crown Imperial
Denver, CO
pianotuna
Regina, SK, Canada
Posted: 01/31/21 01:02am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
A dc to DC charging device would protect the alternator. For a quality device, look at Victron or Outback.
I'm moving to SiO2 batteries myself. They can be used when there is snow on the ground, unlike most LI chemistries and are about 1/2 the price of LI.
Regards, Don
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 01/31/21 02:59am Link  |  Quote  |  Print  |  Notify Moderator
From a U.S. hospital room...
Lestek, put out a good aftermarket product. One stator 2 complete rectifiers.
Enjoy it as is.
steveh27
Grosse Pointe Woods, MI
Posted: 01/31/21 04:47am Link  |  Quote  |  Print  |  Notify Moderator
My alternator cable to the house batts has to go through a battery isolator and then two 40 amp breakers. That would seem to limit the risk.
theoldwizard1
SE MI
Posted: 01/31/21 05:33am Link  |  Quote  |  Print  |  Notify Moderator
Most DC-DC chargers are also isolators.
MEXICOWANDERER
Posted: 01/31/21 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Find LOAD DUMP on Google
Never ever put a circuit breaker between an alternator and battery.
This is a universal rule observed by SAE for sixty years running.
2oldman
NM
Posted: 01/31/21 09:42am Link  |  Quote  |  Print  |  Notify Moderator
You don't have solar?
pianotuna
Regina, SK, Canada
Posted: 01/31/21 09:45am Link  |  Quote  |  Print  |  Notify Moderator
Mex,
I believe the starter battery circuit will remain intact.
The OP has a circuit breaker in the house battery charging circuit. Why he would have two such breakers is a mystery.
time2roll
Posted: 01/31/21 09:50am Link  |  Quote  |  Print  |  Notify Moderator
DC-DC charger would provide two benefits. First in limiting your amps, secondly boosting the voltage to 14.5 or 14.6 to actually charge the battery to full. 14.1 is a bit low for most lithium.
Keep in mind the DC-DC charger can draw up to 50% more amps than rated output.
You could put your DC clamp-on ammeter on the charge wire or better the alternator output and see if you really get excessive amps. Test at home during the install. Then get the DC charger if needed.
675w Solar pictures back up
Son of Norway
Denver, Colorado
Posted: 01/31/21 11:12am Link  |  Quote  |  Print  |  Notify Moderator
Thanks to all. I have 300 watts of solar and I could always run the generator for awhile before I leave the campsite. The circuit between the alternator and the batteries stays closed. The videos I have seen indicate the problem occurs at low RPM. I can see the thing to do would be to run some tests when I install the batteries. I just wanted to have some idea of the other components that I will need in addition to the batteries and how much I will have to modify the system I have now.
Mexico, sorry to hear you are in the hospital. I hope you get well soon.
