RV.Net Open Roads Forum: Truck Campers: Flat
Page of 7
Fishhunter
Alaska
Posted: 01/31/21 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Prolly a dumb question but...do you lift the weight of the camper off the truck before jacking the truck up...never had a flat in all my travels and was just wondering
2021Ram 3500 DRW Torklift Tiedowns, Fastguns
ORV 24RLS Titanium
2015 Adventurer 86FB
Kayteg1
California > Nevada
Posted: 01/31/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
It never hurts to have double protection.
Factory jacks usually can lift truck with its full load, but lot of TC overload rear axle, so common sense apply.
JRscooby
Indepmo
Posted: 01/31/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Jacking 1 wheel will cause a vehicle to lean. If you jack the camper straight up, then bring the truck up at a angle won't that put a lot of stress on camper? Where if the camper and truck are lifted as a unit at least the camper will ride as it normally does.
azdryheat
Tucson, AZ
Posted: 01/31/21 11:27am Link  |  Quote  |  Print  |  Notify Moderator
I had a dually tire fail with my toyhauler hooked up. I carry an 8 ton bottle jack, which lifted the truck just fine. I also got a battery powered hammer wrench when I got home for the next time I get a flat, no more 4 ways.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
ticki2
NH
Posted: 01/31/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
It all depends on the capacity of the jack . Either way will work .
'68 Avion C-11
'02 GMC DRW D/A flatbed
JRscooby
Indepmo
Posted: 01/31/21 11:53am Link  |  Quote  |  Print  |  Notify Moderator
I think you should carry ramp to lift the center of the flat wheel back up to normal height. Jack up from there to get the wheel off block, then off hub. First, much less overall lift with jack, so less likely to fall off. And just holding is not as likely to fall as while jacking. And given a fall, if it happens with the wheel off it is more likely to hurt you or vehicle. If you start up from normal height you don't get flat off, then need to "Up just a little more" to get replacement back on.
JimK-NY
NY
Posted: 01/31/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
Unfasten the fastguns, then use both the camper and truck jacks. In theory the truck jack should work but they are flimsy and even using the camper jacks, my truck jack bent.
Hemi Joel
Minnesota
Posted: 01/31/21 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
I carry an 8 ton bottle jack and some wood blocks. I've changed tires a few times on the road. I just leave the camper on the truck, I don't lower the camper jacks, chock the other wheels, put the bottle jack under the axle tube as far outboard as possible, change the tire, lower the truck. Never had an issue with that method, never saw a need to do it any different.
2018 Eagle Cap 1163 triple slide on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
specta
utah
Posted: 02/01/21 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Best answer so far.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
mkirsch
Rochester, NY
Posted: 02/01/21 07:17am Link  |  Quote  |  Print  |  Notify Moderator
In my case I used the tongue jack of the trailer I was towing in conjunction with the 2-1/2 ton floor jack I keep in said trailer to change the flat I had a few years back.
The axle holds up the weight the rest of the time, a flat tire doesn't change that. There is absolutely no reason to jack the camper separately if you have a jack that can do the job. To that end I suggest dedicating some storage space to a quality 8-12 ton bottle jack.
Page of 7
