RV.Net Open Roads Forum: Truck Campers: Flat
Page of 7
specta
utah
Posted: 02/01/21 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
That settles it. I'm getting a 15-ton bottle jack. [emoticon]
Kenny
2011 Chevy 2500 HD 6.0L 4wd
Kayteg1
California > Nevada
Posted: 02/01/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
JRscooby wrote:
Kayteg1 wrote:
10 tons?
I wonder what it takes to bend the axle?
What does it matter? The jack can't put any more force than what the axle weighs, no matter the capacity..
It does matter when you put the jack under the axle pipe, like most of us do. When you have axle overloaded and lifting it in the point that was not design for it- something will give, just like Titanic broke on several pieces as it could not hold its own weight hanging in the air.
kohldad
Goose Creek, SC
Posted: 02/01/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
Just use the factory jack. Used it on loaded truck, loaded flat bed trailer, among other things. Only time I can remember changing a tire with a bottle jack was on the road when my single axle dump was overloaded with 11 tons in the bed. The 8-ton bottle jack said that was about all it was going to pick up but did get the job done.
Besides, I don't really have the room to carry an extra bottle jack. Space is all taken up as it is and I'm already heavy enough.
2015 Ram 3500 4x4 Crew Cab SRW 6.4 Hemi LB 3.73 (12.4 hand calc avg mpg after 92,000 miles with camper)
2004 Lance 815 (prev: 2004 FW 35'; 1994 TT 30'; Tents)
jimh425
Western MT
Posted: 02/01/21 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
I started carrying a 12 ton bottle jack a few years ago. I would use it instead of the factory jack, but the real answer is I’d probably just call AAA if possible.
One of the reason I bought a 450 is for the 19.5 tires which I feel are much tougher than a normal tire. Hopefully, it means no flat.
Buzzcut1
Norcal
Posted: 02/01/21 10:10pm Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
JRscooby wrote:
Kayteg1 wrote:
10 tons?
If your axle cant take a jack lifting up a little more than half the load that it normally carries down the road then I would say you are driving junk. Seriously we are only talking 4-5000 pounds.
2011 F350 6.7L Diesel 4x4 CrewCab longbed Dually, 08 Lance 1055, Torqlift Talons, Fast Guns, upper and lower Stable Loads, Super Hitch, 48" Super Truss, Airlift loadlifter 5000 extreme airbags
JoeChiOhki
Sauvie Island, OR
Posted: 02/02/21 01:43am Link  |  Quote  |  Print  |  Notify Moderator
Buzzcut1 wrote:
Kayteg1 wrote:
JRscooby wrote:
Kayteg1 wrote:
10 tons?
The difference is in pressure to area applied. Your spring perch transfers the load across the curvature (the strongest part of the tubular structure ) if the axle tube.
With a smaller bottle jack you're concentrating all that weight into a much smaller contact patch, which increases the psi being applied and can damage the tube potentially.
In terms of total weight, that part is moot, the psi at the contact patch is the critical bit.
If you look at most factory jacks, they use a cradle which spreads that contact patch out into the curvature of the axle tube, reducing the total psi, but they are generally only rated fir lifting an unladen truck, not one with a full load in the bed.
My Blog - The Journey of the Redneck Express
CB Channel 17 Redneck Express
'2006 Heartland BigHorn 3400RL
JRscooby
Indepmo
Posted: 02/02/21 04:35am Link  |  Quote  |  Print  |  Notify Moderator
Look at the top of a 6 compared to a 10 ton bottle jack. Yes, the bigger jack could have a bigger contact area, but when you think about that contact with a tube, there is very little increase.
The big issue is people think it is a good idea to put any jack under the tube. Put the jack under where the suspension mounts to axle. Bet if you check the book, that is where the factory says to put the factory jack.
specta
utah
Posted: 02/02/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
Some people need to call and have someone else change the tire.
Its obvious that some are not capable of placing the jack in the proper place so it wont cause any damage.
Good Sam or AAA might be a good choice for them.
mkirsch
Rochester, NY
Posted: 02/02/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
What, you mean at virtually any point along the axle tube's length? I don't doubt some people are incapable of that.
They don't exactly use exhaust pipe for axle tubes. It's pretty stout stuff. Ever cut an axle tube on a 3/4 or 1 ton truck apart? They are seriously THICK walled. Like 3/8" or more. It would take a lot more than the weight of the largest heaviest camper on the market, loaded to the max, to put a dent in one.
specta
utah
Posted: 02/02/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
There are people out there that have no business holding a screwdriver let alone changing a flat tire on a truck with a camper loaded in the bed.
Page of 7
