RV.Net Open Roads Forum: Technology Corner: Office 365 Questions
 > Office 365 Questions
lovemountains
Georgia
Posted: 01/31/21 03:20pm Link  |  Print  |  Notify Moderator
I purchased Microsoft Office 365 when I got a new computer after my laptop died. Why can't I open the Microsoft WORD documents that I had saved to flash drives?
2oldman
NM
Posted: 01/31/21 03:32pm Link  |  Print  |  Notify Moderator
google has some answers
1492
Arlington, VA
Posted: 01/31/21 04:00pm Link  |  Print  |  Notify Moderator
How old are these Word files? MS considers some older files as a possible security risk, so won't open by default. You need to configure settings to allow access to older Word docs. I would then save these in updated Word formats.
lovemountains
Georgia
Posted: 01/31/21 09:09pm Link  |  Print  |  Notify Moderator
They are WORD 2016 documents. Some were saved to my flash drives in the last month or two.
1492
Arlington, VA
Posted: 01/31/21 10:44pm Link  |  Print  |  Notify Moderator
Then they should open. I'm wondering if the Word files somehow got corrupted when saved to the flash drive.
Did you try to open these files from your PC, not from your Flash drive? You can also get a free MS Doc viewer app, or the free Libre
or Open Office suite to see if they will open the files.
* This post was edited 01/31/21 10:52pm by 1492 *
BobsYourUncle
Calgary Alberta Canada
Posted: 02/01/21 06:23am Link  |  Print  |  Notify Moderator
I run Office 365.
I have massive amounts of old documents, some going back into the 90s.
As I go through this stuff to purge it, I open Word, Excel, PP and Pub files with no problems and no errors.
Perhaps, as mentioned, it's something in your settings. I am running all defaults on mine and it has never refused to open files.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Currently under construction, big project! Will change this when done.
RoyF
Fayetteville Arkansas
Posted: 02/01/21 09:27am Link  |  Print  |  Notify Moderator
If the files are corrupted, and if you can run run Unix or Linux, you may at least be able to see the unformated text in filename by using the Unix or Linux command 'hexdump'.
hexdump -C filename > dumpfilename
In Unix, the above would write a dump of filename to dumpfilename.
In Linux, use the option -Canonical instead of -C.
The option causes any printable characters to be displayed alongside each line of the hexadecimal.
The dumpfilename produced by a Word file will contain a lot of gobbledegook in addition to the raw unformatted text.
Added on edit. Sorry, Linux also uses -C. (I use Unix, and don't know Linux.)
* This post was edited 02/01/21 09:46am by RoyF *
RobWNY
Jamestown, NY
Posted: 02/01/21 10:23am Link  |  Print  |  Notify Moderator
If you place those documents back onto your computer, can you open them then? Maybe you have security set up on your flash drive that is preventing MS Office from opening them directly from the flash drive.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
lovemountains
Georgia
Posted: 02/01/21 06:17pm Link  |  Print  |  Notify Moderator
Thanks for all the responses!
When I try to SAVE AS on my new computer with Microsoft 365, I have the following choices: 1. Save a copy online 2. Rename 3. Download as PDF 4. Download as ODT.
Yesterday, I wanted to print one of documents on my flash drive, so I used it on my husband's computer, and had no trouble opening it and printing the document. He has WORD 2016 Teacher and Student, which I had on my old laptop.
lovemountains
Georgia
Posted: 02/01/21 06:22pm Link  |  Print  |  Notify Moderator
I guess I could move my flash drive to my husband's computer and save the documents I want to keep to ONE Drive, then they should be available on my computer. But I wish there was a better solution.
