RV.Net Open Roads Forum: Fifth-Wheels: Morryde Rubber pin box
 > Morryde Rubber pin box
B.O. Plenty
Minnesota
Posted: 02/03/21 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
southernsky wrote:
Spend the extra money and get you an air ride pin box. We have a Reese 5th Airborne.
I have one right now (Lippert Trail Aire) piece of junk. How much good can it really do when it only moves up and down about an inch and a half at the most. It's coming off to be replaced by a MorRyde I have sitting on my garage floor.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
ZeeLet50
Alden, New York
Posted: 02/04/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
There is actually a third option. A 11.5K or less. I bought the 11.5 to 14K one and it moved very little on my 303.You can see where the pucks are sliding and I had about 1/2" of movement of less. So I had to anti up for a lighter spring which works great. With a GVWR of 12K I thought I got the right one at first. But I am never fully loaded and am closer to 11K so the lighter spring (rubber) works for me.
2017 Grand Design Reflection 303RLS towed by a 2016 GMC 2500HD gas with Andersen hitch and B&W turnover ball mount.
Lightning55
Pleasanton, CA
Posted: 02/04/21 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I installed a Morryde pinbox trying to improve the "chucking", jerking motion in my Jayco FW. It doesn't stop the chucking but it dampens the jerking motion enough that I was very pleased with the results. I won't own another FW without installing a Morryde pinbox.
Crabbypatty
Long Island, New York
Posted: 02/05/21 04:17am Link  |  Quote  |  Print  |  Notify Moderator
I have a stock pin box and Pullrite Autoslide 2600. (FR Heritage Glen 326). While I haven't driven to far yet I haven't noticed much of an issue with chucking. I am wondering having seen air ride and more ride boxes at cg's of they raise the height of the fw? Im 13'2" now and not looking to get much taller. Any thoughts on that?
John, Lisa & Tara">">">
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
lenr
Indianapolis, IN
Posted: 02/05/21 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
The MORRyde pin box doesn't raise the height and is adjustable up and down in the frame just like the stock pin box. You have to purchase the MORRyde pin box compatable with the OEM PIN box so all the bolt sizes match and the holes line up. MORRyde lists comparable OEM pin boxes on line. The MORRyde SRE4000 rubberized equalizer does raise the trailer 1.25" but most of us can use the help back there to level the trailer.
Edd505
Elephant Butte, NM
Posted: 02/05/21 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
The 1621 designation is the pin box bolt pattern. The box comes in long or short and the two weight classes. I changed from the SRE3000 to the SRE4000 and saw no differance in height.
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
ZeeLet50
Alden, New York
Posted: 02/06/21 09:44am Link  |  Quote  |  Print  |  Notify Moderator
And if you still have chunking after trying the MorRyde pin box and equalizer, you can always add some kind of damping of suspension using a shock kit or a sumo spring. Lots of options out there.
work2much
On the Road
Posted: 02/06/21 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
If you are getting a new truck and it has the factory puck including a gooseneck ball why not just get a Goose Box. No more cumbersome hitch to remove to use the bed. All the equipment stays with the trailer. The Goose Box is shock dampened and air ride adjustable. Lippert frame warranty approved.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
rhagfo
Portland, OR
Posted: 02/07/21 12:20am Link  |  Quote  |  Print  |  Notify Moderator
The Mor-Ryde pin box will not fix chucking, it just masks it! Consider fixing the root problem, before installing the cushioned pin box. We had a chucking issue with our 2005 Copper Canyon, leveled the trailer when towing, installed shocks on the 5er, and got the pin weight up to 22%, chucking issues gone, no need for the cushioned pin box. If I were to install a cushioned pin box it would be a Mor-Ryde.
TxGearhead
Posted: 02/07/21 05:08am Link  |  Quote  |  Print  |  Notify Moderator
I would ditch the hitch and get the Reese Goosebox.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
