RV.Net Open Roads Forum: Truck Campers: Timbrens,airbags!
 > Timbrens,airbags!
Fishhunter
Alaska
Posted: 02/02/21 11:22am Link  |  Quote  |  Print  |  Notify Moderator
Wondering what would work best for leveling the truck. It’s not bad but I do have vehicles flashing their lights at me at night. Put a set of stableloads on truck but that didn’t seem to help...leaning toward airbags.
2021Ram 3500 DRW Torklift Tiedowns, Fastguns
ORV 24RLS Titanium
2015 Adventurer 86FB
ticki2
NH
Posted: 02/02/21 11:32am Link  |  Quote  |  Print  |  Notify Moderator
Might be easier and cheaper to adjust the headlights
'68 Avion C-11
'02 GMC DRW D/A flatbed
Quartzsite, AZ
Posted: 02/02/21 11:48am Link  |  Quote  |  Print  |  Notify Moderator
I use air bags...ten pounds when not towing and 55-60 or so when towing.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Fishhunter
Alaska
Posted: 02/02/21 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah I been doing that..adjust when putting on and adjust when removing..
Geewizard
WA
Posted: 02/02/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
I sure like my Air Lift Wireless air bag system. Easy to install and use. I recommend it.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
2 Fullriver 100AH AGM batteries
Compressor fridge
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
sonuvabug
Mid-West Ontario, Canada
Posted: 02/02/21 12:33pm Link  |  Quote  |  Print  |  Notify Moderator
Timbrens are similar to my Sumo Springs and I do not think they'll do what you want them to do. I am not a fan of air bags but I believe they are the answer to your needs as described. Make sure you close the loop and let us know what you end up doing.
2007 Adventurer 90fws Truck Camper
2001 FORD F250 SuperCab; 8' box; 4x4, 7.3l diesel, rear Sumo Springs
billtex
RI
Posted: 02/02/21 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Did you add upper or lower SL’s?
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
JimK-NY
NY
Posted: 02/02/21 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
My one experiment with airbags did not go well. Anything above about 20 psi, which barely did anything, gave me a lot of sway. I tried to use them at low pressure for a year or so, then one bag broke and I replaced it. Finally I got rid of both of them and got Supersprings. They worked.
My current truck also gave me a headlights issue. I put on Timbrens and they have helped keep the truck more level. With Covid and crowds in every camping area, I have not gone anywhere since the upgrade, but I think the issue is resolved. If not I will just lower the headlights a tad.
Posted: 02/02/21 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
For your little camper?
Nevermind why you are running air when the truck isn't hauling weight,
but you have a sub 1000lb tongue weight (even if you're not using a wdh) and 55-60 psi will basically put an ad-hoc 3" lift kit in the back.
That much pressure is good for supporting 1500-1600lbs...per side.
How much extra weight are you carrying in the bed. At those pressures, your suspension is good for like 4500lbs of rear axle payload.
Either you mis typed something or your setup is all jacked up, literally and figuratively.
2017 Heartland Torque T29
specta
utah
Posted: 02/02/21 04:28pm Link  |  Quote  |  Print  |  Notify Moderator
I'm happy with my air bags. They work just fine to "level" the truck.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
 > Timbrens,airbags!
